Low-Re Boundary Conditions for K-omega SST (aerodynamics)
Like Tree2Likes
  • 1 Post By openfoamer93
  • 1 Post By steddy
Old   April 29, 2020, 10:30
Default Low-Re Boundary Conditions for K-omega SST (aerodynamics)
Andrea Stedile
steddy is on a distinguished road
Hi all,
Noob here, having a simple question.
Let's take the Motorbike tutorial, that is included in OpenFOAM:
/opt/openfoam7/tutorials/incompressible/simpleFoam/motorBike
How would you modify the files in the '0' folder in order to fully resolve the boundary layer of (both) the motorbike and the floor (Low Reynolds, y+ <= 1)?
I have already seen this post, but it is quite old and I am not sure if it is still valid: k-omega SST and wall functions in OpenFOAM-1.5-dev
I will include for your convenience the code of the k, nut, omega, p, U.orig files.
k
#include        "include/initialConditions"
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform $turbulentKE;
boundaryField
    //- Set patchGroups for constraint patches
    #includeEtc "caseDicts/setConstraintTypes"
    //- Define inlet conditions
    #include "include/fixedInlet"
    outlet
        type            inletOutlet;
        inletValue      $internalField;
        value           $internalField;
    lowerWall
        type            kqRWallFunction;
    motorBikeGroup
    #include "include/frontBackUpperPatches"
nut
boundaryField
    frontAndBack
        type            calculated;
        value           uniform 0;
    inlet
        type            calculated;
        value           uniform 0;
    outlet
        type            calculated;
        value           uniform 0;
    lowerWall
        type            nutkWallFunction;
        value           uniform 0;
    upperWall
        type            calculated;
        value           uniform 0;
    motorBikeGroup
        value           uniform 0;
omega
dimensions      [0 0 -1 0 0 0 0];
internalField   uniform $turbulentOmega;
boundaryField
    outlet
        type            inletOutlet;
    lowerWall
        type            omegaWallFunction;
    motorBikeGroup
p
internalField   uniform $pressure;
boundaryField
    inlet
        type            zeroGradient;
    outlet
        type            fixedValue;
    lowerWall
        type            zeroGradient;
    motorBikeGroup
        type            zeroGradient;
U.orig
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform $flowVelocity;
boundaryField
    outlet
        type            inletOutlet;
        inletValue      uniform (0 0 0);
    lowerWall
        type            fixedValue;
    motorBikeGroup
        type            noSlip;
steddy is offline   Reply With Quote
Old   April 29, 2020, 20:22
Bssam
openfoamer93 is on a distinguished road
I assume that the boundary layer is already refined so that y+<1. If not then try to refine the boundary layer using the command:
refineWallLayer 'patchNmae' 0.5
Then
automatically switches to a low Re in case y+<1 and it resolve the boundary layer without using any wall function and switches to wall function when y+ is large.
No need to modify anything
openfoamer93 is offline   Reply With Quote
Old   April 30, 2020, 06:04
Andrea Stedile
Bassam, thanks for your answer.
Yes, the average yplus is ~0.04 on the whole surface thanks to tiny layers.
Do you have any source to back this up; perhaps an OpenFOAM page I didn't read?
Old   April 30, 2020, 23:05
Bssam
For omega wall function I am sure! You can revise the theory behind this wall function which switch automatically.
However, the k and nut should be:
kLowReWallFunction
nutLowReWallFunction
I just realised that they were not a LowRe
Please revise page 27 from this report that support my claims:
A Thorough Description Of How Wall Functions Are Implemented In OpenFOAM - Chalmers
steddy likes this.
Old   May 1, 2020, 08:39
Andrea Stedile
Thank you very much for your help and time, I will modify accordingly!
openfoamer93 likes this.
Old   May 2, 2020, 17:02
Bssam
So did it work with you? I tried the approach in another case and compared the results to experiment which was satisfactory
Old   May 3, 2020, 06:16
Andrea Stedile
Hi, right now I am trying to replicate in OpenFOAM a Simscale case that investigates the Ahmed body, using the boundary conditions that you suggested. I will get back to you as soon as possible and send you the outcomes when the solver will be done; it will take ~ 1 day because the mesh is pretty fine (18M cells and I am using a server with 8 cores only). Thank you again for your dedication
https://www.simscale.com/projects/gs...ni/ahmed_body/
Old   May 3, 2020, 09:50
Bssam
Wow 18M that definitely needs a cluster computer to handle the case. All the best in your simulations!
boundary conditions, boundary layer, k-omega sst, low-re, yplus
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 18:02
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 08:44
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 04:39
how to calculate the omega at inlet boundary in k omega sst Scabbard OpenFOAM Running, Solving & CFD 2 September 30, 2014 13:06
