FOAM FATAL IO ERROR for chtMultiRegionFoam
Old   May 8, 2012, 16:49
Default FOAM FATAL IO ERROR for chtMultiRegionFoam
YuanLiu
xiaoyoyo is on a distinguished road
Hello Everyone,
I create a case based on this thread:
http://www.cfd-online.com/Forums/ope...tml#post259005
0-folder: contains domain folders with their respective data fields without polyMesh folders.
constant-folder: regionProperties file and domain folders. Each domain has properties files, AND polyMeshes folder.
system: in main folder controlDict and individual domain folders. In domain subfolers: fv-files.
The case worked when I am using the chtMultiRegionSimpleFoam. Then I modified it a little bit,and try to run it using chtMultiRegionFoam command. And I got this error message:
cfx@cfxLinux:~/OpenFOAM/cfx-2.1.0/run/Cooling_try/simpleCylinder01_01$ chtMultiRegionFoam
| \\ / O peration | Version: 2.1.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.1.0-0bc225064152
Exec : chtMultiRegionFoam
Date : May 08 2012
Time : 16:06:04
Host : "cfxLinux"
PID : 25339
Case : /home/cfx/OpenFOAM/cfx-2.1.0/run/Cooling_try/simpleCylinder01_01
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create fluid mesh for region BODYAIR1 for time = 0
--> FOAM FATAL IO ERROR:
cannot open file
file: /home/cfx/OpenFOAM/cfx-2.1.0/run/Cooling_try/simpleCylinder01_01/system/BODYAIR1/fvSchemes at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 87.
FOAM exiting
Hope get valuable suggestions from you!
xiaoyoyo is offline   Reply With Quote
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
