setting momentum source with fieldSources
Hello all,
I am trying to run the channel simulation channelFoam from the tutorials with the pressure gradient set by using the new featurei in OF 2.1: fieldSources. I seems that it should be possible to use this in stead of adding the momentum source in the solver code, as is done channelFoam. However, I got problems with getting it running. In the channel channel395 simulation I have added in the fvSolution the PIMPLE properties and UFinal properties. This allow to run the case with pimpleFoam. In the pimpleFoam solver there is now a momentum source at the right hand side of the U-equation: sources(U). I want to define the pressuregradient, so I have added to following file sourceProperties to the constant directory with the folling contents Code:
presGradient Code:
FOAM FATAL ERROR: Any hints appreciated Regards Eelco |
problem solved
For those interested: it appeared to be a bug in the pimpleFoam of 2.1.0, which is already fixed in pimpeFoam 2.1.x, where the call to the sources(U) term UEqn.H was moved below the declaration of rAU.
I tested the source term on the channelFoam tutorial case by adding the file sourceProperties to the constant directory and run pimpleFoam. Indeed the same results as using channelFoam is obtained. Code:
presGradient |
I noticed this thread, even though it is a bit old - I have a question! When I run pimpleFoam with a pressure source as you describe above, my results seem ok, except for the pressure field. When I observe them in paraview the pressure gradient isn't apparent (I have a PG of 20, but my results don't indicate this). Everything else seems fine! Any help on this would be really appreciated! Best wishes, Jack |
