-   -   Parallel run: boundary condition missing on processorX/0 (http://www.cfd-online.com/Forums/openfoam-solving/101937-parallel-run-boundary-condition-missing-processorx-0-a.html)
lovecraft22 May 17, 2012 10:57
1 Attachment(s)
Hi all;
if you try and run the motorbike tutorial in parallel you'll get an error about the motorbike patch missing within the processors folders.
My error is this one:
keyword cilindro_patch0 is undefined in dictionary "/home/ubuntu/Desktop/condivisa/test/processor0/0/p::boundaryField"
It is actually missing within any of the boundary files held in the 0 folder of every processor folder after running decomposePar.
Now, I read somewhere on the forum that the problem is due to decomposePar which cannot handle all the "#include" inside the boundary files so I got rid of those but… again… the same error…
I enclose my test case. Is a simple cylinder made to speed up the whole process. I started from the motorbike tutorial.
Can anybody please help me understanding how a case needs to be set up to be run in parallel?
Thank you!
lovecraft22 May 17, 2012 13:08
The discussion I was referring is this one:
http://www.cfd-online.com/Forums/ope...omposepar.html
So is using changeDictionary the only way to achieve this? There's must be a way of defining the boundary conditions that doesn't require for the changeDictionary command to be run…
Also, I found out that if I run decomposePar after snappyHexMesh then the error disappears… I can run the solver in parallel then but it would be nice to run snappy as well in parallel…
wyldckat May 21, 2012 16:59
Hi lovecraft22,
I can't go into detail, but you can study the tutorials provided here: http://code.google.com/p/bluecfd-sin...untimes202_211
Best regards,
Bruno
lovecraft22 May 21, 2012 17:07
Thank you Bruno;
I had a quick look and it seems that the boundaries are pretty similar to mine, apart for the "proc.*" entry.
There's a lot of stuff in the allRun instead so I need to have a better look at that.
Thank you!
lovecraft22 May 29, 2012 09:26
Hi Bruno;
could you please explain what's the difference between the method you advised and this one:
http://www.cfd-online.com/Forums/ope...tml#post363548
Thank you very much for your help!
wyldckat May 29, 2012 15:53
Hi lovecraft22,
Originally Posted by lovecraft22 (Post 363585)
Hi Bruno;
If I remember correctly, the examples cases that I referenced above use the same "0" folder throughout most of the Allrun script. It only copies the folder "0.org" to "0" once. Again, this is if I remember correctly.
Another detail was to take into account the changes between scotch and ptscotch for decomposition and snappyHexMesh, respectively.
I believe that the method I used was more generic, since it would work for both 2.0 and 2.1, but in OpenFOAM 2.1 I think it doesn't need to reconstruct the mesh in between... the "motorBike" case in the "les" example demonstrates just that.
Best regards,
Bruno
lovecraft22 May 29, 2012 16:06
Thank you!
