May 22, 2012, 23:23 |
sonicFoam and reconstructPar
Daniel
Rep Power: 16 |
Hello all,
I am having some trouble using reconstructPar and sonicFoam. I have run a case in sonicFoam with an airfoil that changes pitch, and now I wish to use the results as the starting point for another case. I tried the mapFields utility, however there was an error on the k and omega boundary conditions in the mapped files. I traced the error to the reconstructPar utility. I ran the case in parallel, and in the directory for each of the time steps the wall functions for omega and k are the same as for my time 0 BCs: compressible:megaWallFunction and compressible::kqRWallFunction, respectively. However, when the time steps are reconstructed, the BCs are changed to omegaWallFunction and kqRWallFunction. Therefore, I must edit the files manually before continuing to run the case. Does anyone know why that is, or how it can be fixed? Problem 2: after fixing the files manually, the case diverges after one timestep with the famous error: Code:
--> FOAM FATAL ERROR: Maximum number of iterations exceeded From function specieThermo<Thermo>::T(scalar f, scalar T0, scalar (specieThermo<Thermo>::*F)(const scalar) const, scalar (specieThermo<Thermo>::*dFdT)(const scalar) const) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.0.1/src/thermophysicalModels/specie/lnInclude/specieThermoI.H at line 67. Thanks in advance, Dan |
