how to add an extra dimension to internalField data type?
Like Tree1Likes
  • 1 Post By chenhu
Old   May 22, 2012, 04:55
Wink how to add an extra dimension to internalField data type?
Chen Huang
chenhu is on a distinguished road
Hello!
I am wondering if there is anyone who knows how to define a data type with an extra dimension to the internalField data.
E.g. the unburnt temperature at celli can be called as follows,
thermo.Tu().internalField()[celli]
Can I have a data type which has an extra dimension as follows
thermo.Tu().internalField()[celli][extra dimension]?
Thanks for the help!
Chen
chenhu is offline   Reply With Quote
Old   May 23, 2012, 09:19
Default Problem solved!
Chen Huang
I defined a list of volScalarField like following
PtrList<volScalarField> variable(100);
which means variable has 100 elments which are volScalarField.
I call each elements like the following:
variable[1][celli]
which means I call the celli of the second element (a volScalarField).
I can get access of the internal and boundaryField as following,
variable[1].internalField()[celli]
Chen
shash likes this.
transsonic nozzle with rhoSimpleFoam Unseen OpenFOAM Running, Solving & CFD 8 July 1, 2022 06:54
compilation problem with "fvPatch::lookupPatchField" Ya_Squall2010 OpenFOAM Programming & Development 9 November 15, 2021 22:01
rhoSimpleFoam claco OpenFOAM 7 April 20, 2010 04:32
buoyantSimpleRadiationFoam msarkar OpenFOAM 0 February 15, 2010 06:22
pipe flow with heat transfer Fabian OpenFOAM 2 December 12, 2009 04:53
