3D Simulation of Cylinder Traveling Through Pipe
Old   June 25, 2012, 13:28
Default 3D Simulation of Cylinder Traveling Through Pipe
Isaac S
Ice_Man is on a distinguished road
I am trying to create a 3D simulation of a cylindrical "carrier" traveling through a long cylindrical pipe. I am modifying the wingMotion tutorial and I have succesfully changed the geometry and object file to match what I want and I have ran snappyHexMesh and simpleFoam succesfully. Now I want to run pimpleDyMFoam but I am getting the following when I do:
Create time
Create mesh for time = 3
Selecting dynamicFvMesh dynamicMotionSolverFvMesh
Selecting motion solver: displacementLaplacian
Selecting motion diffusion: inverseDistance
--> FOAM Warning :
From function polyBoundaryMesh:atchSet(const wordReList&, const bool) const
in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 573
Cannot find any patch names matching wing
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RASModel
Selecting RAS turbulence model kOmegaSST
kOmegaSSTCoeffs
alphaK1 0.85034;
alphaK2 1;
alphaOmega1 0.5;
alphaOmega2 0.85616;
gamma1 0.5532;
gamma2 0.4403;
beta1 0.075;
beta2 0.0828;
betaStar 0.09;
a1 0.31;
c1 10;
Reading field rAU if present
No field sources present
PIMPLE: no residual control data found. Calculations will employ 2 corrector loops
Starting time loop
End
If anyone has any ideas of what i need to change or if I should be taking a different approach to this 3D-moving-object kind of problem it would be greatly apreciated. Thank you.
Ice_Man is offline   Reply With Quote
Simulation of cylinder aligned in the flow direction using k-e model Eliasjal FLUENT 2 June 13, 2012 08:00
Blockage in pipe ( using solidwork flow simulation) jchow FloEFD, FloWorks & FloTHERM 1 January 16, 2012 16:03
simulation of a flow around cylinder at Re 3900 amine CFX 2 October 8, 2007 06:20
3D LES simulation of a circular cylinder fpz Main CFD Forum 3 June 20, 2005 19:50
Simulation of the Flow past a circular cylinder using STAR-CD M. S. GUEROUACHE Main CFD Forum 0 October 1, 1998 10:51
