help with velocity boundary condition potentialFoam
Old   May 30, 2012, 18:44
Default help with velocity boundary condition potentialFoam
hfc
Hon Fai Choi
hfc is on a distinguished road
I am new to the forum and not a CFD specialist. I am interested in the potentialFoam solver of OpenFOAM because I want to solve the Poisson equation with given velocity boundary conditions. I am currently trying to apply the potentialFoam solver on a rectangular domain. I would like to define velocity boundary conditions on two opposing faces of the rectangle and zero gradient on the other two. I have set up the U and p input files as follow:
p input file:
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
inflow
type calculated;
outflow
type calculated;
side
type zeroGradient;
defaultFaces
type empty;
U input file:
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inflow
type fixedValue;
value uniform (0.707 0.707 0);
outflow
type fixedValue;
side
type zeroGradient;
defaultFaces
type empty;
where 'inflow' and 'outflow' are the opposing faces with velocity BC. I tried to solve this case, but I get the following error:
FOAM FATAL ERROR:
gradientInternalCoeffs cannot be called for a calculatedFvPatchField on patch outflow of field p in file "/home/user/Projects/Foam/case/block_test1/0/p"
You are probably trying to solve for a field with a default boundary condition.
From function calculatedFvPatchField<Type>::gradientInternalCoef fs() const in file /opt/openfoam210/src/finiteVolume/lnInclude/calculatedFvPatchField.C at line 186.
I also tried setting the pressure boundary conditions on 'inflow' and 'outflow' to zeroGradient instead of calculated, which works, but the resulting velocity field is always perpendicular to these boundaries, even if the boundary velocities that I impose are not.
Does anybody have a suggestion to correct this? Maybe I am not using the right type of boundary conditions for the problem that I have in mind. If so, which other boundary condition should I use?
thanks,
Hon Fai
hfc is offline   Reply With Quote
Old   May 31, 2012, 09:17
kmooney's Avatar
Kyle Mooney
kmooney is on a distinguished road
Perhaps give this a try on the inflow and outflow patches. I don't have much experience with potentialFoam however. For most of the incompressible PISO solvers you need to have pressure defined somewhere to make the solution unique.
inflow
        type zeroGradient;
    outflow
        type fixedValue;
value uniform 0;
kmooney is offline   Reply With Quote
Old   May 31, 2012, 19:52
hfc
Hon Fai Choi
Thanks for the suggestion. I have tried what you suggested, but the output velocity does not match the boundary values that I input. The pressure distribution stays uniform across the 'inflow' boundary, and the velocities remain perpendicular to the boundary. From what I understand, the velocity is not explicitly solved for in potentialFoam, but only corrected with the calculated pressure. So perhaps I need to reformulate the Poisson equation in a mixed approach that explicitly solves for the velocity and the pressure? I haven't figured out yet how to do this.
thanks,
Hon Fai
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Robin boundary condition for the velocity fumiya OpenFOAM 4 June 17, 2011 02:58
velocity boundary condition Logan Page OpenFOAM 0 November 19, 2010 17:59
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 06:18
