laplacianFoam run-time error
Old   June 4, 2012, 18:12
Question laplacianFoam run-time error
Eric
industrial0503 is on a distinguished road
Hi I am a new user to openFOAM and have been reading through the users guide, programmers guide and these threads to gain an understanding of OF. I worked through the icoFoam tutorial and felt rather confident and then moved to flange in the laplacianFoam tutorial.
When I execute laplacianFoam in the terminal i get the following error:
--> FOAM FATAL ERROR:
Cannot find fine "points" in directory "polyMesh" in times 0 down to constant
From function Time::findInstance( const fileName&, const word&, const IOobject::readOption, const word&)
in file db/Time/findInstance.C at line 188.
FOAM exiting
Since this is in the tutorial I am not sure what I need to do to get it to run properly.
Thanks for any help!
Eric
industrial0503 is offline   Reply With Quote
Old   June 5, 2012, 04:26
Disabled
anon_a is on a distinguished road
Hello Eric
In the tutorial directories there is usually an "Allrun" script which contains the necessary commands required to run this case. You can execute this by typing ./Allrun or you can just open it with an editor of your choice and study it to see what is going on under the hood (well, at least the top level stuff).
In your case, you got a complain because the mesh was not created before the execution of the solver.
anon_a is offline   Reply With Quote
Old   June 6, 2012, 14:16
Eric
Hi anon_a thanks for your help! I forgot the syntax "./" when running an executable in the terminal!
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 18:54
attach/detach (valve opening/closing) phsieh2005 OpenFOAM Running, Solving & CFD 2 March 21, 2009 05:18
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
