June 5, 2012, 01:30 |
Water level in a rotating tank problem
Krishna Sandeep
Hi everyone
I am completely new to openFOAM and am trying to workout the " water level in a rotating tank" problem. I should find out the new surface of water and the pressure distribution inside the water. Please direct me how to solve it...if anyone have already tried it please give me a link to the files so that i can run the case. |
June 5, 2012, 03:31 |
Is the thank cylindrical and it's just rotating around its center?
June 5, 2012, 06:33 |
Krishna Sandeep
yeah the tank is cylindrical and is rotating about its vertical axis.....i want to see the vortex formation i.e., the shape of the free water surface..
June 5, 2012, 06:36 |
Then you just need to set your cylinder as a rotating wall in your U file;
"cylinder_.*" { type rotatingWallVelocity; origin (0 0 0); axis (0 0 1); omega constant 3000; } |
June 6, 2012, 02:16 |
cfdkid
Hi Lore,Hello sandeep
Is the tank going to be open or closed ? ( free surface model or regular internal flow or closed lid with two fluids (air,water))
________________________________________ Regards, CFDkid It never gets easier You just get Better |
June 6, 2012, 02:46 |
Krishna Sandeep
The tank is closed. assume that the liquid is inviscid and free of surface tension. Water is filled up to half of the tank. What solver should i use? I've been doing the problem similar to that of dam-break case with different initial fields and viscosity and sigma as 0....is this correct?
June 6, 2012, 02:47 |
Krishna Sandeep
The tank is closed. assume that the liquid is inviscid and free of surface tension. Water is filled up to half of the tank. What solver should i use? I've been doing the problem similar to that of dam-break case with different initial fields and viscosity and sigma as 0....is this correct? I ve given the rotating wall condition and can actully feel the wall rotating....
June 11, 2012, 09:20 |
#8 | |
Edward Leonard
November 15, 2014, 10:32 |
Deutschland
Rep Power: 11 |
hi. sandeep,
have you found the solution? |
April 24, 2016, 13:22 |
variable omega according to algorithm calculated value
Muhammad Usman
what if i want to input omega value from an algorithm??? means i am getting rotation value from an algorthm and i want to use it in solver.
February 15, 2018, 05:30 |
Rotating Wall Velocity and Dirichlet
#11 |
Panchatcharam Mariappan
Rep Power: 11 |
I am working on a similar problem. Rotating wall velocity = Dirichlet boundary condition ?? or Are they different? Regards Panch |
rotatingcylinder, waterlevel |
Problem with the 2D rotating blade-CFX-12.1 | Araz | CFX | 5 | September 3, 2011 07:54 |
Rotating problem / transient / 2D | Logan86 | CFX | 6 | July 8, 2011 06:57 |
Simulating air injects to water in a tank | Howard Wang | FloEFD, FloWorks & FloTHERM | 1 | March 16, 2009 03:17 |
Tank problem using CFD | meda | Main CFD Forum | 3 | July 1, 1999 21:44 |
