December 24, 2012, 11:35 |
Solving 2D Heat Transfer Problem
Hello guys,
I am new to openFoam and have some flow problems. Now I would like to solve 2D heat transfer problem with two different solid materials (no flow just conduction). Therefore I have chosen the scalarTransportFoam solver, which solves dT/dt + grad(U*T) + laplace(DT*T) = 0 . Due to the fact that I consider solid materials my U-field is set to zero in the boundary and initial conditions. I would like to know how I can vary my diffusion coefficient/ heat conductivity DT in the field? Therefore I have created a mesh with gmsh that consists of two sets. When running gmshToFoam in the folder constant/polyMesh/sets two files "Pipe" and "Filling" are created. How can specify the value of DT for the two sets in the transportProperties file? Or am I on the path for such a problem? Kind regards and merry Chrismas! Sebastian |
Display Modes | |
Interfoam blows on parallel run | danvica | OpenFOAM Running, Solving & CFD | 16 | December 22, 2012 03:09 |
Low Mach number Compressible jet flow using LES | ankgupta8um | OpenFOAM Running, Solving & CFD | 7 | January 15, 2011 14:38 |
Problems with simulating TurbFOAM | barath.ezhilan | OpenFOAM | 13 | July 16, 2009 06:55 |
Computational time | sunnysun | OpenFOAM Running, Solving & CFD | 5 | March 16, 2009 04:32 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 12:16 |
