-   -   rhoCentralFoam - Problem high difference pressure (http://www.cfd-online.com/Forums/openfoam-solving/103112-rhocentralfoam-problem-high-difference-pressure.html)
Nicolas_OF June 11, 2012 09:29
I'm new to OpenFoam (2.1.0). I try to simulate underexpanded axisymmetric supersonic flow of Argon. I used tutorial model : LadenburgJet60Psi.My simulation seems to work when difference between inlet and chamber pressure is small (factor of 10). But when this ratio becomes of the order of 1000, I get the famous error "floating exception point". I attempt different parameters, boundaries and I don't success to find where is my error.
Can Openfoam solve this kind of problem ?
Thank you and sorry for my English.
Here my parameters :
BlockMesh :
convertToMeters 0.001;
vertices
( 0 0 0)
(18 0 0)
( 0 1 -0.008726655121)
(18 1 -0.008726655121)
( 0 9 -0.017453310242)
(18 9 -0.017453310242)
( 0 1 0.008726655121)
(18 1 0.008726655121)
( 0 9 0.017453310242)
(18 9 0.017453310242)
blocks
hex (0 1 3 2 0 1 7 6) (60 10 1) simpleGrading (1 1 1)
hex (2 3 5 4 6 7 9 8) (60 10 1) simpleGrading (1 1 1)
edges
boundary
inlet
type patch;
faces
(0 2 6 0)
outlet
type patch;
faces
(1 3 7 1)
(3 5 9 7)
freestreamInlet
type patch;
faces
(2 4 8 6)
freestream
type patch;
faces
(4 8 9 5)
wedge1
type wedge;
faces
(0 2 3 1)
(2 4 5 3)
wedge2
type wedge;
faces
(0 1 7 6)
(6 7 9 8)
mergePatchPairs
ThermoPhysicalProperties :
thermoType ePsiThermo<pureMixture<sutherlandTransport<specieT hermo<hConstThermo<perfectGas>>>>>;
mixture
specie
nMoles 1;
molWeight 39.948;
thermodynamics
Cp 520;
Hf 30;
transport
As 2.054e-06;
Ts 162.4;
p :
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 101;
boundaryField
inlet
type fixedValue;
value uniform 271724;
outlet
type waveTransmissive;
field p;
phi phi;
rho rho;
psi psi;
fieldInf 101;
gamma 1.67;
lInf 0.025;
value uniform 101;
freestream
type totalPressure;
value uniform 101;
p0 uniform 101;
U U;
phi phi;
rho none;
psi psi;
gamma 1.67;
freestreamInlet
type zeroGradient;
wedge1 {type wedge;}
wedge2 {type wedge;}
T :
dimensions [0 0 0 1 0 0 0];
internalField uniform 98.0;
boundaryField
inlet
type fixedValue;
value uniform 299.1;
outlet
type zeroGradient;
freestream
type totalTemperature;
value uniform 97;
T0 uniform 97;
U U;
phi phi;
rho none;
psi psi;
gamma 1.67;
freestreamInlet
type fixedValue;
value uniform 97.0;
U :
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type fixedValue;
value uniform (515.6 0 0);
outlet
type inletOutlet;
inletValue uniform (0 0 0);
value uniform (0 0 0);
freestream
type zeroGradient;
freestreamInlet
type fixedValue;
