| Nathan_Donaldson |
June 20, 2012 07:05 |
rhocentralFoam error while modelling hypersonic flow
Hello all,
I'm a newcomer to OpenFOAM and am trying to model a hypersonic calibration model using rhoCentralFoam. After completing the Wedge15Ma5 and motorBike tutorials, I successfully created a mesh of my geometry using snappyHexMesh.
The problem I'm having is that whenever I run the case and post-process it, the results (velocity, temperature and pressure) are all completely uniform. checkMesh returns no errors, and I've used a very small time step (0.001). Also, the mean and maximum Courant numbers remain constant between iterations, and the residuals prefixed with 'rho' are perpetually 0.
The freestream boundary conditions I've tried to code are:
Mach number = 17.8
Pressure = 29.5 Pa
Temperature = 287K
I've pasted in the Ma, p, U, T and blockMeshDict files below. Are there any errors that are immediately obvious? I'm sure it'll be something basic that I'm missing.
Many thanks,
Nathan
| \\ / O peration | Version: 2.1.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volScalarField;
object Ma;
dimensions [0 0 0 0 0 0 0];
internalField uniform 17.8;
boundaryField
frontAndBack
type symmetryPlane;
outlet
type calculated;
value uniform 17.8;
inlet
type calculated;
value uniform 17.8;
lowerAndUpperWall
type symmetryPlane;
"HB2.*"
type calculated;
defaultFaces
type empty;
FoamFile
version 2.0;
format ascii;
object p;
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 29.5;
boundaryField
frontAndBack
type symmetryPlane;
inlet
type zeroGradient;
value uniform 29.5;
outlet
type zeroGradient;
value uniform 29.5;
lowerAndUpperWall
type symmetryPlane;
"HB2.*"
type zeroGradient;
defaultFaces
type empty;
FoamFile
version 2.0;
format ascii;
object T;
dimensions [0 0 0 1 0 0 0];
internalField uniform 287;
boundaryField
frontAndBack
type symmetryPlane;
inlet
type fixedValue;
value uniform 287;
outlet
type inletOutlet;
inletValue uniform 287;
value uniform 287;
lowerAndUpperWall
type symmetryPlane;
"HB2.*"
type zeroGradient;
defaultFaces
type empty;
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (17.8 0 0);
boundaryField
frontAndBack
type symmetryPlane;
inlet
type fixedValue;
value uniform (17.8 0 0);
outlet
type inletOutlet;
inletValue uniform (17.8 0 0);
lowerAndUpperWall
type symmetryPlane;
"HB2.*"
type zeroGradient;
defaultFaces
type empty;
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1;
vertices
(-100 -50 -50)
(-100 50 -50)
(-100 50 50)
(-100 -50 50)
(400 -50 -50)
(400 50 -50)
(400 50 50)
(400 -50 50)
blocks
hex (0 1 2 3 4 5 6 7) (10 10 50) simpleGrading (1 1 1)
edges
boundary
frontAndBack
type symmetryPlane;
faces
(2 3 7 6)
(0 1 5 4)
inlet
type patch;
faces
(0 3 2 1)
outlet
type patch;
faces
(4 5 6 7)
lowerAndUpperWall
type symmetryPlane;
faces
(0 4 7 3)
(1 2 6 5)
