PDRFoam tutorial
Old   June 20, 2012, 11:00
Default PDRFoam tutorial
Francesco
Bombolati is on a distinguished road
Hi, I'd like to try the tutorial of PDRFoam solver. I go in the correct path and I launch the blockMesh command. Now the mesh is complete and I can launch the solver typing PDRFoam. Unfortunately the case gets the error:
--> FOAM FATAL IO ERROR:
cannot find file
file: /home/francesco/OpenFOAM/francesco-2.1.0/run/tutorials/combustion/PDRFoam/flamePropagationWithObstacles/constant/betav at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
The solution seems simple by copying the file <<betav>> in the <<costant>> folder, but after this kind of error occurs:
/home/francesco/Scrivania/tutorials/combustion/PDRFoam/flamePropagationWithObstacles/0/betav
What's wrong? Another question is: what kind of files are <<Allrun>> and <<Allclean>>? Do I have to use them?
Thanks a lot,
best regards
Bombolati is offline   Reply With Quote
Tutorial for subcooled nucleate boiling Asghari FLUENT 42 December 10, 2018 11:42
Problem on Fluent Tutorial: Horizontal Film Boilig Feng FLUENT 2 April 13, 2013 05:34
Rotor/stator tutorial, and how to... gilberto CFX 5 January 21, 2002 09:41
