y+ useless
Like Tree1Likes
  • 1 Post By colinB
Old   June 21, 2012, 04:12
Default y+ useless
Juancho Pérez
nachettito is on a distinguished road
Hi Foamers,
I'm pretty new to this world of CFD,but i've spent enough hours to get some experience.
The thing is:i've studied a NACA airfoil for incompressible flow using a simpleFoam solver.My turbulence model is a k-omegaSST.
After all this research and basing on my results,the y+ factor gots no sense for me,i.e,some posts suggest that this factor should be kept between 30 and 60.Well,in my case,the range comes from 60 reaching 250 in some areas.
The results obtained compared with experimental data stay around 10 %,a sensible border,and the postprocessing seems to be very accurate too.
Now,I'm starting to the interesting world of compressible flows.So the thing is:should I keep taking into account the y+?
I will appreciate any comments,suggestions or doubts about this respect.
Thanks mates
nachettito is offline   Reply With Quote
Old   June 21, 2012, 05:41
colinB is on a distinguished road
Hi there,
the y+ value is not useless at all. However it is just an indication of your
mesh resolution close to walls.
For a DNS the y+ value should be 1.
But this kind of calculations take a lot of time and consequently are not
commonly used in the industry, for usually they want to have the results
quick.
So some day somebody had the idea to use RANS. This goes much faster
and still delivers results with a reasonable accuracy for the industry.
To 'close' this set of equations one uses turbulence models, but these
however need special consideration for near wall effects (boundary layer),
which is done by introducing wall functions.
These wall functions also lower the required resolution of the boundary
so the y+ values may also increase up to 300 dependant on the wall
function.
So this value is 'just' an indicator of your mesh resolution in the boundary
layer and that your results are deviating not so much is due to the fact
that with a max y+ of 250 you are still under the threshold of 300.
best regards
Colin
Djub likes this.
colinB is offline   Reply With Quote
Old   June 21, 2012, 08:24
Juancho Pérez
Very grateful for your quick response.
Some concepts have cleared my mind,but digging in the point:300 is a good approach in compressible or 3D?I struggle with the same problems in these cases.
Could i know in advance which of the wall functions get a wider number of possible y+?
Looking forward to hearing from you
Old   June 21, 2012, 10:06
concerning 3D:
y+ is the non dimensionless cell hight of the first cell normal to the wall.
So it doesn't care about 2 or 3D
concerning compressible flows:
I have to admit I haven't done anything with that yet so I cannot say how it
is influenced by y+.
concerning different wall functions I recommend you google or the cfd-online
wiki.
More over you want to look at a book called:
Boundary Layer Theory by H. Schlichting
It tells you all you must know for boundary layer modelling
regards
Colin
Old   June 28, 2012, 10:27
Mina
Mina_Shahi is on a distinguished road
Originally Posted by colinB View Post
Hi there,
quick.
function.
best regards
Colin
Hi Colin
I knew that there are 3 parts in boundary layer: 1- viscous sublayer (y+<5), 2- buffer layer (<5<y+<30) 3- log layer. and i know that wall functions are valid for y+ higher than 11 (lets say if the node is located in logaritmic layer) but on the other hand for accuaracy we need mesh refinmet close to the wall which make y+ smaller (not good for wall function but good for accuracy).
Can you explain that what happens for y+<11? I guess that turbulence equatuion will be integrated untill the wall in th eregion with y+<11?
Thank you
Thank you
Mina_Shahi is offline   Reply With Quote
Old   June 29, 2012, 05:40
Dear Mina_Shahi,
I have to admit, that I don't know what is happening below this value.
But you might want to have a look at Pope, Turbulent flows, he explained
in some separate chapters wall functions and their relation to y+ values.
Sorry that I can't further help you
regards
Colin
Old   June 29, 2012, 05:59
Mina
Dear Mina_Shahi,
regards
Colin
Thanks Colin
Unfortunately i don't have access to this book, Do you have those chapters?
Old   July 10, 2012, 08:45
Sorry for the late reply,
but I'm afraid I can't provide you the chapters mentioned.
regards
Colin
Old   July 17, 2012, 11:49
Andrew Coughtrie
Andrew.Coughtrie is on a distinguished road
If you keep your y+ between 30-300 then wall functions are fine, above 11 they might be ok but the results can start to fall apart, below 11 wall functions become numerically diffusive and the results pretty unrealistic.
The kOmegaSST model in OpenFOAM (1.7.1 and above) uses a blended wall treatment devised by Florian Menter (see his papers on the SST model for more info) for this you should either have a y+>30 or y+<5 in the former situation it will use a wall function approach the latter will use a viscous sublayer model to resolve the flow.
For compressible flow the y+ is going to be dependent on the local density.
useful link
http://www.cfd-online.com/Wiki/Y_plu...nce_estimation
Andy
Andrew.Coughtrie is offline   Reply With Quote
Grid check failed .... run simulation useless? Zigainer FLUENT 2 May 17, 2012 04:31
Useless patch beto OpenFOAM Running, Solving & CFD 3 November 19, 2009 07:38
1 billions cells: useless? Sarah Palin Main CFD Forum 72 November 28, 2008 17:31
ILU for Navier stokes problems Raju Main CFD Forum 5 July 29, 2006 14:15
