Incompressible, miscible mixing of two fluid stream OpenFOAM
Old   June 22, 2012, 05:42
Default Incompressible, miscible mixing of two fluid stream OpenFOAM
N Agrawal
Nishchal is on a distinguished road
I am very new to openFOAM and this forum. To get feel of OpenFOAM i decided to setup a test case involving mixing of two fluid stream (compressible and miscible).
It is not a two-phase situation i am dealing with, it is one phase (water) at two different temperatures mixing in a T-junction.
Can anyone suggest me which solver to use?
Nishchal is offline   Reply With Quote
Old   June 23, 2012, 15:49
Retired Super Moderator
Bruno Santos
Greetings Nishchal,
I'm no expert on this subject, so until someone more experienced responds, here's what I know...
If you check the folder "heatTransfer" in the OpenFOAM "tutorials" folder, you'll find these solver tutorials:
buoyantBoussinesqPimpleFoam
buoyantBoussinesqSimpleFoam
buoyantPimpleFoam
buoyantSimpleFoam
buoyantSimpleRadiationFoam
chtMultiRegionFoam
chtMultiRegionSimpleFoam
"Simple" ones are for stationary simulations; "Pimple" ones are for transient simulations; "chtMultiRegion" ones are for multiple mesh domains with different fluids/solids.
Best regards,
Bruno
Old   July 31, 2013, 01:18
Vishal
inf.vish is on a distinguished road
Hi Nishchal,
Did you find out which solver to use and what boundary conditions to use?
I am also looking at the same problem and have been stuck on it for three days now. I am not able to find this simple example anywhere.
inf.vish is offline   Reply With Quote
Old   July 31, 2013, 09:52
Default multiphase flow solver would be the option in my guess
Anil Kunwar
Annier is an unknown quantity at this point
since the pure substance is having different thermodynamic states before mixing, it may be somehow relevant to treat them as two different fluids? if the compressibility can be ignored, twoLiquidMixingFoam is there as a standard solver in OpenFoam. otherwise, you need to modify this solver by adding the codes related to the compressibility of the fluids. still you can search for other relevant solvers which may best fit your physical model.
Annier is offline   Reply With Quote
Old   July 31, 2013, 09:54
Vishal
i used buoyantBoussinesqSimpleFoam. But i will try with twoLiquidMixingFoam also. Thanks
Old   October 8, 2019, 08:28
Mohamed Bennour
mbennour is on a distinguished road
hi Vishal
I'm new with openfoam and I want to ask you how did you setup you boundary Condition for U and T ( in my case i have two Outlets and two Inlets and two fluids with different temperature that they wil be mixed up ) I'm using also buoyantBoussineqsSimpleFoam.
thank u so much for any inofrmation
mbennour is offline   Reply With Quote
Old   October 9, 2019, 06:55
Mohamed Bennour
Hi Annier,
how could you set up the temperature of your fluids with twoLiquidMIxingFoam solver?
In my case have to mix up to liquid with two different temperature (cold and hot Water)
thx
incompressible fluid, miscible, mixing fluid, openfoam 2.1
Newbie: advantages/disadvantages of "penalty formulation" incompressible fluid flow bzz77 Main CFD Forum 2 November 1, 2011 03:32
Placing second fluid in OpenFOAM. vivek070176 OpenFOAM 5 June 30, 2011 18:33
mixing of non reacting miscible fluids Himanshu Arora FLUENT 0 June 13, 2005 04:17
internal steady incompressible inviscid fluid flow Nina Shokina Main CFD Forum 0 October 21, 2003 06:11
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
