June 24, 2013, 06:58 |
AMI-Rotary Spheroidal Interface
reza sadeghi
Rep Power: 12 |
Hi everybody
I am new in OF and I am going to use OF AMI application.I know AMI uses cylindrical zone as an interface, but my rotary interface isn't cylindrical. my case is a rotary spheroidal zone in a cubic domain. can I do my case using OF? Please give me some hints about AMI ability. Thanks in advance, Reza Last edited by reza1111; July 1, 2013 at 06:40. |
June 26, 2013, 07:28 |
reza sadeghi
Rep Power: 12 |
any idea?
July 9, 2013, 11:42 |
Artur
Rep Power: 19 |
I've never tried a spheroidal boundary but can give you a link to a post where I explained how I set up an AMi interface using an .stl file: http://www.cfd-online.com/Forums/ope...pyhexmesh.html After the steps described here I simply followed the propeller tutorial steps (topoSet, createPatch, createBaffles, mergeOrSplitBaffles -split). I'm pretty sure if you make the .stl a sphere it would work. I'm also pretty sure, however, that you will have to choose your mesh settings very well and match them to the rotational speed of your mesh because otherwise you will suffer from floating point exceptions which occur when you get partial overlap of AMI faces (I was getting a lot of that with a poorly defined AMI itnerface). |
July 19, 2013, 17:19 |
reza sadeghi
Rep Power: 12 |
Thanks alot for your reply.
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
