-   -   Forces for airfoil test case (http://www.cfd-online.com/Forums/openfoam-solving/103938-forces-airfoil-test-case.html)
Martin_ June 29, 2012 08:59
I would like to use the 'libforces.so' with simpleFoam to compute forces and force coefficients on an airfoil. I have several issues to which I didn't find answers in the documentation, so I hoped someone could be so kind and help me out.
First, the airfoil consists of multiple parts, let's say surface1, surface2, surface3. Is there a way of listing on which surfaces the forces should be computed? I tried to set the following in the controlDict file:
forces
  type forceCoeffs;
  functionObjectLibs ( "libforces.so" );
  patches (surface1,surface3);
Unfortunately, OpenFOAM doesn't like this syntax. I tried to create a list of names:
airfoil_surfaces
  surface1;
  surface3;
forces
  type forceCoeffs;
  patches ($airfoil_surfaces);
Again, OpenFOAM is not happy with this. Is there a way of specifying the surfaces on which forces should be computed? Should I repeate the whole forces{ ... } block with different patch names?
Second, I would like to get both forces AND force coefficients. Therefore I wrote:
functions
    forces
        type                forces;
    forces
        type forceCoeffs;
OpenFOAM outputs only one file with entries such as this:
# Time  forces(pressure, viscous) moment(pressure, viscous)
500 (((5.55683 -156.714 1.05751e-18) (-0.628621 0.13499 1.34059e-19)) ((43.0962 1.52813 -82.8966) (-0.0371222 -0.172871 0.000622457)))
I don't understand what am I looking at: why are there four triples of numbers for one time step? What do they mean?
Finally, I would really like to compute the aerodynamic center of the airfoil. Is this possible with OpenFOAM?
Thank you for every suggestion how to solve this.
Best regards,
Martin Vymazal
jferrari July 2, 2012 11:58
forces
  type forceCoeffs;
airfoil_surfaces
  surface1;
  surface3;
forces
  type forceCoeffs;
functions
    forces
        type                forces;
    forces
        type forceCoeffs;
Best regards,
Martin Vymazal
Have you tried different combinations? Such as a line for each surface? Or calling the forces function for each surface? I haven't done this before, so I'm not speaking from experience, I'm just thinking out loud.
I believe that OpenFOAM spits out 4 sets of 3 values because it is the x, y, z pressure and viscous forces and moments.
When you call the forces libraray you specify an origin and axis about which you calculate moments. If you have the moments and the axis location, you can set up a statics problem to calculate where your aerodynamic center is.
