[swak4Foam] Problem: Defining a linear scalar BC with groovyBC |
July 11, 2012, 17:22 |
Hello everybody,
I'm new in this forum, so first: greetings everyone Im currently in my 4th semester and was assigned a project which mainly involves openFoam. I was hoping you could help me with a problem, it would be very much appreciated. I have to define a linear temperature distribution as B.C. over the lateral surface of a cylinder (along the z-axis). Since I couldn't find any tutorial how to adapt / write my own B.C. (it's also a bit complicated for a beginner), I wanted to use groovyBC in order to define the boundary condition. My problem: it doesn't work. Or put another way: I screwed something up. I downloaded the swak4Foam GNU tarball, executed wmake all and added libs ("libOpenFOAM.so""libgroovyBC.so"); to my controlDict. I then tried to define my B.C in the 0/T file: Code:
surface { type groovyBC; variables "zp = pos().z; m = pts().z ;minZ = min(m); maxZ =max(m)"; valueExpression "200 + (zp) / (maxZ - minZ)) * 100"; value uniform 1; } valueExpression "100*pos().z"; and used the mag() function since I wasn't enterely sure whether I was dealing with scalar values. Nothing worked. When I execute paraFoam before calculating anything, the default value uniform 1 is always being used. Executing my modified IcoFoam solver, openFoam gives a bug report and crashes. Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading transportProperties Reading field p Reading field T Reading field U Reading/calculating face flux field phi Starting time loop Time = 1 Courant Number mean: 0 max: 0 DILUPBiCG: Solving for Ux, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for Uz, Initial residual = 0, Final residual = 0, No Iterations 0 DICPCG: Solving for p, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 0, global = 0, cumulative = 0 DICPCG: Solving for p, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 0, global = 0, cumulative = 0 word::stripInvalid() called for word zp For debug level (= 2) > 1 this is considered fatal } holp |
July 14, 2012, 06:30 |
#2 | ||
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
July 19, 2012, 08:46 |
Thank you very much for your answer, and also my apologies for answering one week late.
I managed to get it running by not defining the variables and only using the valueExpression term. But it's always good to know what caused the problem - might save me quite some trouble in the future. I didn't expect that problem, because every (programming) language I ever dealt with absolutely ignores blank spaces. You programmed swak4Foam? Respect, and thanks a lot! holp |
July 19, 2012, 20:19 |
#4 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
You're welcome. And as I said above: best "Thank you" is writing precise bug report on the Mantis, because the only three priorities for me to improve swak are: client demands, stuff that interests me and stuff that touches my ego (and keeping the number of bugs in the swak/openfoam-extend-Mantis low is important to my ego) |
Division by zero exception - loop over scalarField | Pat84 | OpenFOAM Programming & Development | 6 | February 18, 2017 05:57 |
[swak4Foam] GroovyBC problem in the defining inlet velocity | iampolaris | OpenFOAM Community Contributions | 7 | October 18, 2014 09:25 |
suitable boundary condition for scavenging process? | immortality | OpenFOAM Running, Solving & CFD | 3 | January 25, 2013 19:10 |
solution diverges when linear upwind interpolation scheme is used | subash | OpenFOAM | 0 | May 29, 2010 01:23 |
