Relative Fluxes in icoDyMFoam
Old   September 22, 2008, 15:59
Default I'm wondering why fluxes are m
Sandeep Menon
deepsterblue will become famous soon enough
I'm wondering why fluxes are made relative to the mesh-motion at the end of the PISO loop in icoDyMFoam:
for (int corr=0; corr<nCorr; corr++)
rUA = 1.0/UEqn.A();
U = rUA*UEqn.H();
// Make the fluxes relative to the mesh motion - why?
fvc::makeRelative(phi, U);
U -= rUA*fvc::grad(p);
U.correctBoundaryConditions();
I'm guessing that this is required for the correctBoundaryConditions call for velocity. Can anyone confirm/explain why this is so?
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
deepsterblue is offline   Reply With Quote
Old   September 23, 2008, 01:27
Default Hy Sandeep, If I remember r
Jens Klostermann
jens_klostermann is on a distinguished road
Hy Sandeep,
If I remember right is this because of the space conservation law and the additional flux which is associated with a moving boundary (mesh).
Jens
jens_klostermann is offline   Reply With Quote
Old   September 23, 2008, 01:57
Default Hi Sandeep, Read any paper
lillberg's Avatar
Eric Lillberg
lillberg is on a distinguished road
Send a message via Skype™ to lillberg
Hi Sandeep,
Read any paper on Arbitrary Lagrangian Eulerian (ALE) methods and it will all be clear. For example Charbel Farhat, "The Discrete Geometric Conservation Law and the Nonlinear Stability of ALE Schemes for the Solution of Flow Problems on Moving Grids", Journal of Computational Physics 174, 669&ndash;694 (2001) or more recent papers on mesh motion by ˇZeljko Tukovi'c.
/Eric
lillberg is offline   Reply With Quote
Old   September 23, 2008, 10:27
Default Hello Jens and Eric, Thanks
Sandeep Menon
Thanks for the help, but it still isn't clear. The makeRelative function merely subtracts meshPhi from phi. However, for the next iteration of the nCorr loop, phi is over-written by:
phi = (fvc::interpolate(U) & mesh.Sf());
The line:
doesn't require phi in any way, and the only reason phi should be relative to mesh-motion (in my opinion) is to satisfy a particular boundary-condition (at U.correctBoundaryConditions()) which requires it to be so. If none of the boundary conditions require it, is the line really necessary?
Comments?
Sandeep Menon
Old   September 25, 2008, 05:49
Default Hi Sandeep, Yes you are rig
Zeljko Tukovic
ztukovic is on a distinguished road
Hi Sandeep,
Yes you are right. You will need relative flux at that stage only if velocity boundary condition requires it. But you will also need relative flux in the turbDyMFoam solver because the transport equations of a turbulence model will require relative flux.
Regards,
Zeljko
ztukovic is offline   Reply With Quote
Old   October 6, 2009, 10:38
Mark
mgeiger is on a distinguished road
Hello!
This thread has been quiet for a while. But what I don't understand about makeRelative and makeAbsolute is, how makeRelative can be called twice without makeAbsolute in between?
The interDyMFoam solver calls:
Abs
Rel
     if ...{
       Rel
       Abs
   Rel
Obviously, the flux is made relative either inside or after the if{} although it is already relative. How should I understand this?
Here are the relevant calls with all for{} loops and if{} conditions:
while (runTime.run())
        // Make the fluxes absolute
        fvc::makeAbsolute(phi, U);
        mesh.update();
        // --- PIMPLE loop
        for (int ocorr=0; ocorr<nOuterCorr; ocorr++)
            // --- PISO loop
                if (p.needReference())
                    adjustPhi(phi, U, p);
regards
Mark
mgeiger is offline   Reply With Quote
Old   April 2, 2012, 04:46
fisch
fisch is on a distinguished road
Hello Mark,
did you find an answer to your question?
I'm interested.
thanks
fisch is offline   Reply With Quote
Old   July 20, 2012, 02:39
Yogesh Bapat
ybapat is on a distinguished road
Hello Mark,
Did you find answer to your question? Please let me know .
ybapat is offline   Reply With Quote
Update Fluxes luca OpenFOAM Running, Solving & CFD 2 March 29, 2006 10:47
Fluxes selen Siemens 1 August 24, 2003 16:23
Fluxes validation Mavinakere FLUENT 0 May 22, 2002 23:24
Help need on fluxes Zhu Main CFD Forum 7 August 12, 2001 10:14
help needed on fluxes zhu Phoenics 0 August 7, 2001 21:35
