Home > Forums > OpenFOAM Running, Solving & CFD
Problems to sample a plane (X-Y-Plane) through the Fluid
Old   July 20, 2012, 09:40
Default Problems to sample a plane (X-Y-Plane) through the Fluid
Sören
despaired student is on a distinguished road
I've tried the sample utility to get some pictures of the flow (magU) but I always get the error massage that something is wrong within the "surfaces" code.
Here is my sampleDict file:
| \\ / O peration | Version: 2.0.1 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object sampleSurfaceDict;
interpolationScheme cellPoint;
surfaceFormat vtk;
surfaces
firstSegment
basePoint ( -6 6 7 );
normalVector ( 0 0 1 );
interpolate false ;
fields ( magU );
and here is the error-message:
--> FOAM FATAL IO ERROR:
keyword type is undefined in dictionary "/apistemp/sm1/ss/Meshs/Test_2_Umlenkplatten_65_Grad/system/sampleDict::surfaces"
file: /apistemp/sm1/ss/Meshs/Test_2_Umlenkplatten_65_Grad/system/sampleDict::surfaces from line 27 to line 29.
From function dictionary::lookupEntry(const word&, bool, bool) const
in file db/dictionary/dictionary.C at line 400.
FOAM exiting
Kind regards
despaired student is offline   Reply With Quote
Old   July 21, 2012, 12:57
Assistant Moderator
Bernhard Gschaider
Originally Posted by despaired student View Post
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
surfaceFormat vtk;
surfaces
firstSegment
interpolate false ;
fields ( magU );
FOAM exiting
Kind regards
I think the error message is a perfectly clear English sentence. Maybe if I rewrite it slightly:
The keyword "type" is undefined in your dictionary named surfaces in your file "/apistemp/sm1/ss/Meshs/Test_2_Umlenkplatten_65_Grad/system/sampleDict"
(but I think Hemingway would have preferred the way OpenFOAM say it)
Old   July 21, 2012, 13:15
Mike Jaworski
Jaworski.Mike is on a distinguished road
Here's another hint:
Look in the tutorial for the plateHole stress analysis. A sampleDict and sampleSurfaceDict are both available. look for your missing keyword in the sampleDict file and see what you need to do.
Jaworski.Mike is offline   Reply With Quote
Old   July 21, 2012, 20:00
Sören
I've looked in the plateHole tutorial, that's where I copied my sampleDict from - more or less. I also tried to "name a type" like the error-message says but it doesn't work...
Old   September 27, 2013, 06:35
Przemek
gaza is on a distinguished road
Hi Soren
in sampleSurfaceDict is an error. There should not be word "name" but "type"
and not "plate" but "plane". You can see correct sampleDict file in $FOAM_UTILITIES/postProcessing/sampling/sample
Of course you have to change sampleSurfaceDict on sampleDict before you execute sample command.
best
gaza is offline   Reply With Quote
Thread Tools
Trackbacks are On
Sample utility problems msrinath80 OpenFOAM Running, Solving & CFD 12 December 21, 2012 06:51
How to choose the mean diameter value for dispersed fluid? creddy_trddc CFX 1 October 30, 2011 05:30
How to use / How to find IPMT? camoesas CFX 2 November 23, 2010 07:36
heat conducting in a solid domain Rogerio Fernandes Brito NUMECA 0 March 18, 2008 18:24
Intl Conf Computational Methods in Fluid Power Jacek Stecki Main CFD Forum 0 November 10, 2002 06:49
