Home > Forums > OpenFOAM Running, Solving & CFD
Iterations and Residuals
Like Tree2Likes
  • 2 Post By chegdan
Old   July 20, 2012, 16:56
Default Iterations and Residuals
David
PEM_GUY is on a distinguished road
So - I have read through the existing threads in this area, but I don't believe there is one that directly addresses a solution for this.
the standard output from a solver is
t=0
(sweep dir 0) initial residual: final residual: iterations
(sweep dir 1) initial residual: final residual: iterations
(sweep dir 2) initial residual: final residual: iterations
t= 1..n
now what I am looking for is -- I want to see the change in residual in each iteration. However, I have found no way to do this to this point.
I have seen that you can use maxIter and the residual keywords to make the time stepping output as iterations if this was a steady state case (still not ideal).
but if there was a way to output the iterations at each sweep this would be applicable for monitoring my time advance, as well as for steady state.
does anyone know if this is available to do, and if so how?
thanks!
PEM_GUY is offline   Reply With Quote
Old   July 26, 2012, 16:48
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Hi, PEM_GUY, FOAM has a set of flags that allow you to select the level of verbosity of at run-time. I can't remember now, but increasing the verbosity level in solving could give you the information you want.
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Post-doctoral Fellow
Research Center for Computational Mechanics (CIMEC) - CONICET/FICH-UNL
T.E.: 54-342-4511594 Ext. 1005
Güemes 3450 - (3000) Santa Fe
Santa Fe - Argentina
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   July 30, 2012, 14:24
chegdan's Avatar
Daniel P. Combest
chegdan will become famous soon enough
Regards.
set the lduMatrix flag to 2 in the global controlDict file in
$HOME/OpenFOAM/OpenFOAM-2.1.x/etc
and that should give you more information about the inner iterations..
wyldckat and Bahram like this.
Dan
Find me on twitter @dancombest and LinkedIn
chegdan is offline   Reply With Quote
Thread Tools
Trackbacks are On
OpenFOAM - structured or unstructured Grids ? thomasduerr OpenFOAM Meshing & Mesh Conversion 18 October 10, 2014 06:31
plot residuals in multiregion solver val46 OpenFOAM 3 September 7, 2012 02:59
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
Residuals maka OpenFOAM Bugs 0 August 4, 2008 14:07
Modeling in micron scale using icoFoam m9819348 OpenFOAM Running, Solving & CFD 7 October 27, 2007 00:36
