July 25, 2012, 17:26 |
Residuals problem
Rep Power: 14 |
Hi foamers,
I have been trying to model flow through a Nozzle, the geometry of which can be seen in the attached picture. I have a flowRateInletVelocity BC at my inlet, where the flowRate is being ramped from 0.001 to 0.00397 in 0.001 increments every 100 time steps. The pressure blows up when I run the simulation and gives some strange residuals. I have not encountered residuals like these before (see 2nd attached picture). Does anyone have any ideas that will help me maintain a steady residual for my pressure? Thank you in advance for any help that anyone can offer. Kind Regards, Tom |
July 26, 2012, 11:25 |
You don't specify the solver you use in this case but I guessed it is a single phase flow solver (pisoFOAM) with turbulence model. From what I saw in the residuals, I think it is not converged due to the lack of PISO loop. I think if you try to increase the number of correctors in fvSolution until the initial residual of p decreases to 10^-5 or so and use momentum predictor if required, that problem might disappear.
And if it is the convergence problems of the solver (looking at the final residual of p in the log file), you might want to use another solver, smoother etc. Hope it can help. Duong |
July 26, 2012, 17:25 |
Rep Power: 14 |
Hi Duong,
Thanks for your reply, I am using rhoSimpleBaffleFoam a modified version of the rhoSimpleFoam solver, I must use this solver so I can't change it. However I will look into your suggestions nonetheless. Thanks Tom |
Display Modes | |
Problem with residuals, especially continuity | Ozgur_ | FLUENT | 2 | December 3, 2013 05:48 |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 19:42 |
Can I solve this problem by Fluent? | Kai_kc | FLUENT | 1 | October 27, 2010 05:29 |
Convergence - scaled vs unscaled residuals | HS | FLUENT | 1 | November 7, 2005 05:45 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
