March 27, 2012, 02:50 |
chtMultiRegionFoam running in parallel
Sebastian
Rep Power: 16 |
Hello Foamers,
I've got a problem regarding parallel processing and conjugate heat transfer. I have 2 regions, solid and fluid. I've generated the mesh with snappyHexMesh. When I run it on an single Processor the computation is stable and the results are ok. But when I decompose the Case an run in in parallel mode the computation becomes unstable and stops. I use OoenFoam 2.1.0. Did somebody observes the same problem? Thanks in advance sebastian |
July 30, 2012, 03:10 |
Unnikrishnan Mohankumar
Rep Power: 15 |
Dear Sebastine,
I have the same problem.. Did you find some solution for this. Regards Unnikrishnan. |
openfoam, parallel, snappyhexmesh |
OF 2.0.1 parallel running problems | moser_r | OpenFOAM Running, Solving & CFD | 9 | July 27, 2022 03:15 |
Parallel operation of chtMultiRegionFoam | pizzaice | OpenFOAM Running, Solving & CFD | 0 | February 5, 2010 11:38 |
Statically Compiling OpenFOAM Issues | herzfeldd | OpenFOAM Installation | 21 | January 6, 2009 09:38 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 07:52 |
running multiple Fluent parallel jobs | Michael Bo Hansen | FLUENT | 8 | June 7, 2006 08:52 |
