-   -   Contrib wpcRAS: utility to calculate wind pressure coefficient (http://www.cfd-online.com/Forums/openfoam-solving/105541-contrib-wpcras-utility-calculate-wind-pressure-coefficient.html)
hfs August 2, 2012 04:44
I just found this tool to calculate wind pressure coefficients (works for OF1.6, OF2.0)
http://openfoamwiki.net/index.php/Contrib_wpcRAS
I tried it on OF 2.1.x... did not work..
I hope that I can find a similar tool for OF 2.1.x
Any ideas??
roth November 12, 2012 12:35
octree stuff changed
In readDict.H comment out all the octree stuff and replace with a single line i.e. modify as per below:
    Info << "Reference Static Pressure Location = " <<
        referenceStaticPressureLocation << endl;
    //~ // make octree  data cells
    //~ const cellList& cells = mesh.cells();
    //~ const pointField& points = mesh.points();
    //~ treeBoundBox meshBb(points);
    //~ scalar typDim = meshBb.avgDim()/(2.0*pow(cells.size(), 1.0/3.0));
    //~ treeBoundBox shiftedBb
        //~ meshBb.min() - vector(typDim, typDim, typDim),
        //~ meshBb.max() + vector(typDim, typDim, typDim)
    //~ octreeDataCell shapes(mesh);
    //~ octree<octreeDataCell> oc
        //~ shiftedBb,  // overall bounding box
        //~ shapes,    // all information needed to do checks on cells
        //~ 1,          // min. levels
        //~ 10.0,      // max. size of leaves
        //~ 10.0        // maximum ratio of cubes v.s. cells
    // label cellRefPstat = oc.find(referenceStaticPressureLocation);
    label cellRefPstat = mesh.findCell(referenceStaticPressureLocation);
and comment out the octree stuff in wpcRAS.C:
#include "incompressible/RAS/RASModel/RASModel.H"
//~ #include "octree.h"
//~ #include "octreeDataCell.H"
#include "wallFvPatch.H"
Should work. I just grabbed a mesh lookup from the probes source code.
