--> FOAM FATAL IO ERROR: Unable to set reference cell for field p Please supply
When I want to run my simulation with pimpleDyMFoam command I get the following error Message: --> FOAM FATAL IO ERROR: Unable to set reference cell for field p Please supply either pRefCell or pRefPoint Does anybody now where I can supply either pRefCell or pRefPoint? Thanks in advance, alex |
Hi
check this out: Code:
less $FOAM_TUTORIALS/incompressible/pimpleDyMFoam/mixerVesselAMI2D/system/fvSolution |
Thanks Phicau,
found it. Regards, Alex |
Thanks Phicau. I also ran across the same error.
An example of the dict for potentialFoam
I also came across similar problem, potentialFoam complained about pRefCell, phiRefCell, and Phi. Luckily after adding those keywords to fvSolution, it solved.
Here are several keywords you may need. Code:
PIMPLE |
Dear users,
I do have exacly the same pRefCell error than Alexander but I already have the code of fvSolutions as you mentioned, with pRefCell 0; and pRefValue 0; set. Does anyone know what is going on? |
Most likely your simulation doesn't like cell 0. You can try pRefPoint and set a point somewhere in your domain.
flowModel consistentIcoFlow; icoFlowCoeffs { nCorrectors 3; nNonOrthogonalCorrectors 1; pRefCell 0; pRefValue 0; } //consistentIcoFlowCoeffs consistentIcoFlowCoeffs; { nCorrectors 3; nNonOrthogonalCorrectors 1; pRefCell 0; pRefValue 0; } |
