August 5, 2012, 17:02 |
Rep Power: 14 |
I am trying to incorporate energy generation within my domain. I want to add a energy source term into the domain without adding a surface and discretizing the source term. The application I am using is buoyantBoussinesqSimpleFoam. Any suggestions or a tutorial available?
Thanks for the help in advance! Last edited by fontania; August 5, 2012 at 18:00. Reason: added some information |
Enforce bounds error with heat loss boundary condition at solid walls | Chander | CFX | 2 | May 1, 2012 20:11 |
temperature dependent internal heat generation | dbrodrigues | ANSYS | 0 | March 31, 2012 01:16 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
Time Dependent Heat Sources | Leon Mills | Phoenics | 1 | July 3, 2001 05:22 |
Heat Generation as time dependent problem | Denis Kadito | FLUENT | 0 | April 17, 2001 16:28 |
