January 10, 2010, 19:31 |
OpenFoam parallel scalability
Steve Colde
Rep Power: 16 |
Hi, I am testing OpenFoam scalability on cluster system (> 100 cores). I found test cases from tutorial is very small and can't scale.
Can anyone provide some test cases scales or the way to increase test case size? Thanks a lot. Steve |
January 11, 2010, 03:52 |
Patricio Bohorquez
Rep Power: 17 |
You may try the Lid-driven cavity flow tutorial in order to compare your speed-up results with, for instance, those reported for Murska and Louhi (Cray XT) servers . You just need to increase the cell numbers in the X-Y-Z directions up to the desired resolution:
cd ~/OpenFOAM/OpenFOAM-1.5-dev/tutorials/icoFoam/cavity vim constant/polyMesh/blockMeshDict edit the bold text in the following line: hex (0 1 2 3 4 5 6 7) (20 20 1) simpleGrading (1 1 1) to (200 200 200) to attain 8M cells. blockMesh decomposePar run icoFoam in parallel mode, etc See also the results in the ENEA-GRID environment: OpenFOAM parallel performances |
January 11, 2010, 12:33 |
Steve Colde
Rep Power: 16 |
Thanks Patricio.
But I can't locate cavity/system/decomposeParDict which is required by decomposePar and mpirun -np 16 icoFoam -case cavity -parallel. |
January 11, 2010, 13:04 |
Patricio Bohorquez
Rep Power: 17 |
You can copy and edit the default file which is located in the folder that follows:
~/OpenFOAM/OpenFOAM-1.5-dev/applications/utilities/parallelProcessing/decomposePar/decomposeParDict Please notice that the decomposition method may affect strongly the speed-up. Therefore, you should test which is the best approach for your platform. Furthermore, I would suggest to play with the OptimisationSwitches 'floatTransfer' and 'commsType' which are located at the global controlDict: ~/OpenFOAM/OpenFOAM-1.5-dev/etc/controlDict Finally, if you employ a direct solver, you must 'renumberMesh' in order to reduce the bandwidth of the discretized system of equations. You will find more information surfing the forum. Good luck, Patricio. |
January 12, 2010, 02:38 |
Steve Colde
Rep Power: 16 |
Patrico, how can I change dimension to 3D, i think (20, 20.1 ) is two dimension, but your (200,200,200) is 3D.
Thanks Steve |
January 12, 2010, 02:45 |
Patricio Bohorquez
Rep Power: 17 |
Just replace (20, 20, 1) with (200, 200, 200) and edit the boundary conditions at t=0:
- For the pressure: the face frontAndBack from empty to zeroGradient. - For the velocity: the face frontAndBack from empty to fixedValue; value uniform (0 0 0) Last edited by pbohorquez; January 12, 2010 at 05:27. |
January 12, 2010, 03:16 |
Steve Colde
Rep Power: 16 |
Also, for increasing number of cpu cores to execute the test case, do i only need to modify the following two entries: numberofsubdomains and n (4 4 1)?
Seems like execution time becomes even longer as cpu number increases. numberOfSubdomains 16; //- Keep owner and neighbour on same processor for faces in zones: // preserveFaceZones (heater solid1 solid3); //method scotch; // method hierarchical; method simple; // method metis; // method manual; simpleCoeffs { n (4 4 1); delta 0.001; } |
January 12, 2010, 03:29 |
Patricio Bohorquez
Rep Power: 17 |
Yes, that's all. Have you tried decreasing the number of cores/cells? Maybe the cache is a bottleneck.
Are you using infiniband or similar? Could I know the hardware characteristics? /proc/cpuinfo /proc/meminfo numactl --hardware |
January 12, 2010, 12:44 |
#9 |
Steve Colde
Rep Power: 16 |
cat /proc/meminfo
MemTotal: 16508772 kB MemFree: 11369420 kB Buffers: 676276 kB Cached: 3823348 kB cat /proc/cpuinfo Quad-Core AMD Opteron(tm) Processor 2382 stepping : 2 cpu MHz : 2600.000 cache size : 512 KB numactl --hardware available: 2 nodes (0-1) node 0 size: 8066 MB node 0 free: 5250 MB node 1 size: 8080 MB node 1 free: 5852 MB node distances: node 0 1 0: 10 20 1: 20 10 I am using cavity from tutorial which is 2D: icoFoam/cavity 1. Changed cavity/constant/polyMesh/blockMeshDict to increase cell size: blocks ( hex (0 1 2 3 4 5 6 7) (100 100 1) simpleGrading (1 1 1) ); 2. In cavity/system/decomposeParDict: numberOfSubdomains 16; method simple; simpleCoeffs { n (4 4 1); delta 0.001; } mpirun -np 16 -hostfile host-dell icoFoam -case cavity -parallel |
January 12, 2010, 14:53 |
#10 |
Steve Colde
Rep Power: 16 |
BTW, i am using compiled openfoam-1.6 binary from openfoam website.
I don't need to recompile to get reasonable performance, right? |
January 13, 2010, 08:08 |
#11 |
Patricio Bohorquez
Rep Power: 17 |
Steve, to check the scaling it is not necessary to recompile OF. However, you could compare the runtime with and without optimization options. To recompile OF:
echo $WM_OPTIONS : I suppose you will get 'linux64GccDPOpt' foam : in order to change the path to ~/OpenFOAM/OpenFOAM-1.6 cd wmake/rules edit the files c++Opt and cOpt which are located at linux64Gcc with the tuning options you best. foam ./Allwmake But you should obtain first the 2D scaling, subsequently the 3D and finally repeat the process with the optimization flags. Well, in my experience 2D cases scale much better than 3D. So both benchmarks are useful. Before running with 16 cores, try running a 1M-cells case only in one node with 1, 2, 4 and 8 threads and see what happens. |
January 13, 2010, 15:12 |
#12 |
Steve Colde
Rep Power: 16 |
To use 1M cell in 2D
It should look like this (1000 1000 1), right? I also need to modify delta=0.1/1000 What else to change? I am getting error with this. It works with smaller config (200 200 1) [87] [99] #0 Foam::error:rintStack(Foam::Ostream&)#[90] #0 Foam::error:rintStack(Foam::Ostream&)[159] #0 Foam::error:rintStack(Foam::Ostream&)[44] #0 Foam::error:rintStack(Foam::Ostream&)[12] #0 Foam::error:rintStack(Foam::Ostream&)0[189] #0 Foam::error:rintStack(Foam::Ostream&)[13] #0 Foam::error:rintStack(Foam::Ostream&) Foam::error:rintStack(Foam::Ostream&) in "/application/OpenFOAM/OpenFOAM-1. in in "/application/OpenFOAM/OpenF"/application/OpenFOAM/OpenFOAM-1OAM-1.6/lib/linux64Gcc6/lib/linux64GccDPOpt/libOpenFOAM.so" [159] in #1 Foam::sigFpe::sigFpeHandler(int)".6/lib/linux64GccDPOpt/libODPOpt/libOpenFOAM.so" /penFOAM.so" [90] #[99] #1 a1 Foam::sigFpe::sigFpeHandler(int)Foam::sigFpe::sigF peHandler(int)p in p"/application/OpenFOAM/OpenFOAlicaM-1.6/lib/linux64GccDPOpt/libOpetnFOAM.so" i[44] #1 oFoam::sigFpe::sigFpeHandler(int)n/Op in enF"/application/OpenFOAM/OpenFOAM/OpOAM-1.6/lib/linux64GcceDPOpt/libOpenFOAM.so"n [189] #F1 OFoam::sigFpe::sigFpeHandler(int)AM-1.6/lib/linux64GccDPOpt/libO in p"/application/OpenFOAM/OpenFOAM-1.e6/lib/linux64GccDPOpt/nFOAM.libOpenFOAM.so" s[13] #1 oFoam::sigFpe::sigFpeHandler(int)" [87] #1 Foam::sigFpe::sigFpeHandler(int) in "/application/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" [12] #1 Foam::sigFpe::sigFpeHandler(int) in "/application/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" [13] #2 in "/application/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" [12] #2 in "/application/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" [90] #2 in "/application/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" [44] #2 in "/application/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" [189] #2 __restore_rt__restore_rt__restore_rt__restore_rt at sigaction.c:0 __restore_rt[13] #3 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at sigaction.c:0 [12] #3 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/application/OpenFOAM/Ope at sigaction.c:0 [90] #n3 FFoam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) constOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.s at osigaction.c:0 [44] #3 "Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const [87] #2 at sigaction.c:0 [189] #3 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/application/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" [13] #4 in "/application/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" [90] #4 in "/application/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" [159] #2 in "/application/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" [44] #4 in "/application/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" [12] #4 in "/application/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" [99] #2 in "/application/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" [189] #4 Foam::fvMatrix<Foam::Vector<double> >::solve(Foam::dictionary const&)__restore_rtFoam::fvMatrix<Foam::Vector<dou ble> >::solve(Foam::dictionary const&) in "/application/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/icoFoam" [13] #5 __restore_rt in "/application/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/icoFoam" [12] #5 Foam::fvMatrix<Foam::Vector<double> >::solve(Foam::dictionary const&)Foam::fvMatrix<Foam::Vector<double> >::solve(Foam::dictionary const&)Foam::fvMatrix<Foam::Vector<double> >::solve(Foam::dictionary const&) at sigaction.c:0 [159] #3 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) constmain__restore_rt at sigaction.c:0 [87] #3 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/applica in "/application/OpenFOAM/OpenFOAM-1.tion/OpenFOAM/Open6/applications/bin/linuxFOAM-1.6/ap64GccDPOpt/icoFoam" plications/bin/linux64G[13] #6 ccDPOpt/icoFoam" __libc_start_main[44] #5 main in "/application/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/icoFoam" [90] #5 at sigaction.c:0 [99] #3 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/application/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" [159] #4 in "/application/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/icoFoam" [12] #6 __libc_start_main in "/lib64/libc.so.6" [13] #7 in "/application/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" [99] #4 in "/application/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/icoFoam" [189] #5 in "/lib64/libc.so.6" [12] #7 in "/application/OpFoam::fvMatrix<Foam::Vector<double> >::solve(Foam::dictionary const&)enFOAM/OpenFOAM-1.6/li_startb/linux64GccDPOpt/libOpenFoam::fvMatrix<Foam::Vector<double> >::solve(Foam::dictionary const&)FOAM.so" [87] #4 mainmain at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116 |
January 13, 2010, 15:53 |
#13 |
Patricio Bohorquez
Rep Power: 17 |
Are you getting that error at t=0 or later? It works for me during the first time steps (later i stoped it) for a similar hardware and OF-1.6.x. Strange ... theoretically the time step "delta=0.1/1000" is right, but in view of the current error please decrease it down to "delta=0.04/1000" and modify the convective scheme in system/fvSchemes from "div(phi,U) Gauss linear;" to "div(phi,U) Gauss upwind;" Does it work?
January 13, 2010, 15:59 |
#14 |
Steve Colde
Rep Power: 16 |
How do i know if it is after t=0?
January 13, 2010, 16:07 |
#15 |
Steve Colde
Rep Power: 16 |
To add more
it actually runs for about 15 steps then failed ... ... ... Courant Number mean: 1.22202e+63 max: 7.75973e+67 DILUPBiCG: Solving for Ux, Initial residual = 0.999995, Final residual = 1.16608, No Iterations 1001 DILUPBiCG: Solving for Uy, Initial residual = 0.999996, Final residual = 1.09995, No Iterations 1001 DICPCG: Solving for p, Initial residual = 1, Final residual = 66.4662, No Iterations 1001 time step continuity errors : sum local = 4.02726e+74, global = 3.83607e+58, cumulative = 3.83607e+58 DICPCG: Solving for p, Initial residual = 0.957693, Final residual = 58.9586, No Iterations 1001 time step continuity errors : sum local = 5.18098e+77, global = -5.68607e+60, cumulative = -5.64771e+60 ExecutionTime = 84.67 s ClockTime = 85 s Time = 0.0014 Courant Number mean: 5.23134e+77 max: 5.91045e+82 DILUPBiCG: Solving for Ux, Initial residual = 0.999997, Final residual = 1.04889, No Iterations 1001 DILUPBiCG: Solving for Uy, Initial residual = 0.999998, Final residual = 1.03628, No Iterations 1001 DICPCG: Solving for p, Initial residual = 1, Final residual = 5.03803, No Iterations 1001 time step continuity errors : sum local = 4.55256e+87, global = -8.81927e+70, cumulative = -8.81927e+70 DICPCG: Solving for p, Initial residual = 0.945851, Final residual = 1.31256, No Iterations 1001 time step continuity errors : sum local = 4.95068e+89, global = -5.33324e+73, cumulative = -5.34206e+73 ExecutionTime = 92.46 s ClockTime = 92 s Time = 0.0015 |
January 13, 2010, 16:12 |
#16 |
Patricio Bohorquez
Rep Power: 17 |
Thanks. Now it's clear:
Courant Number mean: 5.23134e+77 max: 5.91045e+82 The simulation crashes because of the increase of the max Courant number that must lie below 1. Please change the time step and the convective scheme as described above. |
January 13, 2010, 16:18 |
#17 |
Steve Colde
Rep Power: 16 |
I changed to 0.04/1000 and fvSchemes accordingly but it still failed at
Courant Number mean: 1.01438e+28 max: 1.1376e+34 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 6.56472e-06, No Iterations 847 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 7.58524e-06, No Iterations 793 DICPCG: Solving for p, Initial residual = 1, Final residual = 9.52153e-07, No Iterations 36 time step continuity errors : sum local = 1.21105e+47, global = -5.76682e+30, cumulative = -5.76682e+30 DICPCG: Solving for p, Initial residual = 0.986946, Final residual = 2.25487e-10, No Iterations 2 time step continuity errors : sum local = 6.90662e+48, global = 1.29807e+32, cumulative = 1.24041e+32 ExecutionTime = 108.37 s ClockTime = 108 s Time = 0.00084 Courant Number mean: 2.00307e+48 max: 2.56405e+54 DILUPBiCG: Solving for Ux, Initial residual = 0.999993, Final residual = 21424.5, No Iterations 1001 DILUPBiCG: Solving for Uy, Initial residual = 0.999993, Final residual = 4.22121e+06, No Iterations 1001 DICPCG: Solving for p, Initial residual = 1, Final residual = 5.8586e-09, No Iterations 8 time step continuity errors : sum local = 9.89617e+97, global = 4.42758e+87, cumulative = 4.42758e+87 DICPCG: Solving for p, Initial residual = 0.8704, Final residual = 1.84481e-07, No Iterations 8 time step continuity errors : sum local = 4.71685e+99, global = -2.7024e+88, cumulative = -2.25964e+88 ExecutionTime = 113.58 s ClockTime = 113 s Time = 0.00088 Courant Number mean: 5.94215e+103 max: 2.46371e+109 |
January 13, 2010, 16:29 |
#18 |
Patricio Bohorquez
Rep Power: 17 |
OK. Try to converge the solution at every time step:
Increase "nCorrectors" in system/fvSolution up to the required number in order to obtain the Initial residual of 'p' of order 10^{-3} at the end of the PISO loop. For instance, start with nCorrectors=20. |
January 13, 2010, 16:59 |
#19 |
Steve Colde
Rep Power: 16 |
looks like it is working with this change.
i am wondering if this will dramatically impact scalability/speedup? |
January 13, 2010, 17:02 |
#20 |
Steve Colde
Rep Power: 16 |
Also can i specify end time at shorter time
Changing from 0.5 to 0.0026, can this represent the complete run in terms of performance? |
Display Modes | |
running OpenFoam in parallel | vishwa | OpenFOAM Running, Solving & CFD | 22 | August 2, 2015 08:53 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
Testing OpenFOAM parallel computing | jason.ryon | OpenFOAM | 0 | October 5, 2009 11:46 |
Parallel solution in OpenFOAM | makaveli_lcf | OpenFOAM Running, Solving & CFD | 0 | September 21, 2009 08:07 |
Modified OpenFOAM Forum Structure and New Mailing-List | pete | Site News & Announcements | 0 | June 29, 2009 05:56 |
