Problem in Running OF!!!! please Help me
hi everybody,
before, I had CAELinux 2011 and it have a OpenFOAM Terminal, I start it and running my models in OF. Now, I install Ubuntu 11.04 and OpenFOAM-2.1.0, the first time it worked correctly, but I closed the Terminal and when I run it again and write blockMesh it says command not found. I don't know how run it?!?!? I'm pretty a new user of Linux. Engineers, can you explain me how can I run the OF with details?!?!?!? Thanks a lot, Mostafa Mahmoudi |
Hi Mostafa,
Since you asked with details, here you go: Advanced tips for working with the OpenFOAM shell environment But you can simply run: Code:
echo "source $HOME/OpenFOAM/OpenFOAM-2.1.0/etc/bashrc" >> $HOME/.bashrc Best regards, Bruno |
the link was so useful. I ran the code you suggest, but after it whenever I open the Terminal it is just an OpenFOAM Terminal!!!!!!! :eek: how can I back to the original Terminal? |
I just feel like you simply don't learn anything from my blog post :(
Here's a quick fix: Code:
sed -i -e 's-^\(source '$HOME'.*\)-alias of210="\1"-' $HOME/.bashrc Now, for each new terminal where you want to run OpenFOAM 2.1.0, run once the following command: Code:
of210 |
It works. before I made this thread, I had searched the forum and found your link, I applied what that said but it didn't work. a new problem: when I run the code you presented in the last post, there is no result, just the pointer twinkles and the terminal seems to calculating something. when I press Ctrl+C it stops and I can use OpenFOAM. did I make a mistake in installing OF?!?!?!? Thank you |
What do the last lines of the file "$HOME/.bashrc" contain?
