OpenFoam Solid Stress Anlalisys
Like Tree1Likes
  • 1 Post By bigphil
Old   August 30, 2012, 20:37
Default OpenFoam Solid Stress Anlalisys
Humberto
tokotico is on a distinguished road
Hello I am trying to do stress analysis of a Structural insulated panel, with SolidEquilibriumDisplacementFoam, without luck, here is case directory to download:
http://www.filedropper.com/sip
Somehow the solution is not generating any stresses inside the panel.
Please any help will be greatly appreciated.
tokotico is offline   Reply With Quote
Old   August 31, 2012, 19:42
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
What errors are you getting?
I had a quick look at your case and your mechanical properties are not declared correctly (as in the $FOAM_TUTORIALS/stressAnalysis/solidEquilibriumDisplacementFoam/beamEndLoad case).
Also you have a defaultFaces patch which is empty.
Philip
bigphil is offline   Reply With Quote
Old   August 31, 2012, 23:21
Humberto
Originally Posted by bigphil View Post
Philip
Thanks Philip, I checked the mechanical properties and it is exactly as the one on the tutorials, only changed the value for E and rho.
The defaultFaces patch I included it because it also exists on the tutorial.
the behavior is strange, the program only runs for nu = 0 and at the end the panel shows with 0 stress and 0 deformation everywhere. If I change nu=0.2 the solver crashes on iteration 550.
while solving it alwas shows
kineticEnergy = 0
kineticPower = 0
smi = 0
so basically nothing is happening I do not understand why!!!.
Old   September 1, 2012, 10:12
bigphil's Avatar
Philip Cardiff
Ah the mechanicalProperties definition has changed in the standard OpenFOAM, OK that's fine.
As regards the defaultFaces patch, you have the boundary condition set to empty on this patch, but you can only use empty for 1-D or 2-D cases and your case is 3-D so I presume this boundary conditions is meant to be traction-free or something like that?
Also, has the case converged i.e. have you run the case for multiple time-steps OR have you increased the number of outer correctors?
Philip
Old   September 10, 2012, 18:46
Default Various Materials
Humberto
Thanks for all your help Bigphil, I got rid of the empty patches thanks for the observation, but still it does not even converge.
I was wondering, How do I define two different materials right now I have
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object mechanicalProperties;
rho
type uniform;
value 1200;
nu
type uniform;
value 0.1;
E
type uniform;
value 5558500000;
planeStress no;
Thanks in advance for all your help!!!
Old   September 12, 2012, 04:36
bigphil's Avatar
Philip Cardiff
Hi Humberto,
To begin with, I would recommend you use "solidDisplacementFoam" in preference to "solidEquilibriumDisplacementFoam" even for steady state simulations (solidEquilibriumDisplacementFoams implementation tries to increase the convergence of steady state models using some tricks but I have found that it does not converge for Poisson's ratio's greater than zero). solidDisplacementFoam can simulate steady state by setting the d2dt2Scheme to steadyState.
This will probably fix your convergence issues.
As regards multi-material, you could replace the rho, nu, E uniform fields with non-uniform fields, however, I am not sure if there is a utility to do this. So I would recommend you use the solidMechanics solvers in OpenFOAM-1.6-ext which allow straight-forward simulation of multi-material bodies, however I am a bit biased .
The tutorial OpenFOAM-1.6-ext/applications/solvers/solidMechanics/tutorials/elasticSolidFoam/bimaterialCase shows how to do it.
Philip
Old   September 19, 2012, 08:13
Daniel Chrastina
shpalman is on a distinguished road
Send a message via Yahoo to shpalman Send a message via Skype™ to shpalman
I also worked on modifying the solidDisplacementFoam solver to incorporate varying material parameters as fields in the same mesh, it "worked" in the sense that it converged and gave an output (identical to solidDisplacementFoam in the case of homogenous material), but I'm not sure about the physical reliability of the result.
I'm still using 1.7.x since when I first tried version 2 it tended to diverge. I might try 2.1.x.
Also I wrote something to extract the strain, if that's ever useful to anyone else.
shpalman is offline   Reply With Quote
Old   October 6, 2012, 19:15
jon pry
jonpry is on a distinguished road
I would be very interested in the codes for heterogeneous material parameters and strain extraction. Please post/send me contact info.
Thanks,
Jon Pry
jonpry is offline   Reply With Quote
Old   October 7, 2012, 07:13
bigphil's Avatar
Philip Cardiff
Thanks,
Jon Pry
Hi Jon,
As I mentioned previously there are solvers in the solidMechanics branch of OpenFOAM-1.6-ext which are specifically designed for heterogeneous material properties. There has also been a paper recently published which is the basis of the adopted methods. Additionally strain fields are output.
Best regards,
Philip
wuwenbo likes this.
problem with Min/max rho tH3f0rC3 OpenFOAM 8 July 31, 2019 09:48
Is there any anisotropic solver for solid stress analysis? stickjohnson OpenFOAM 6 October 31, 2011 14:51
What BC for a solid in OpenFoam? cristina87 OpenFOAM 2 May 11, 2011 18:15
Defining Solid Zones Not working elmcmaster FLUENT 3 May 22, 2009 07:14
OpenFOAM Training in Europe and USA hjasak OpenFOAM 0 August 8, 2008 05:33
