flow around cylinder
I'm a new user of openFOAM and I'm trying to simulate flow around a cylinder. I use pisoFoam as a solver, but get the follwoing error.
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RASModel Selecting RAS turbulence model kEpsilon bounding k, min: 0 max: 0.00325 average: 0.00325 bounding epsilon, min: 0 max: 0.000765 average: 0.000765 #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #4 void Foam::divide<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so" #5 at kEpsilon.C:0 #6 Foam::incompressible::RASModels::kEpsilon::kEpsilo n(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&, Foam::word const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so" #7 Foam::incompressible::RASModel::adddictionaryConst ructorToTable<Foam::incompressible::RASModels::kEp silon>::New(Foam::GeometricField<Foam::Vector<doub le>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so" #8 Foam::incompressible::RASModel::New(Foam::Geometri cField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so" #9 Foam::incompressible::turbulenceModel::addturbulen ceModelConstructorToTable<Foam::incompressible::RA SModel>::NewturbulenceModel(Foam::GeometricField<F oam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so" #10 Foam::incompressible::turbulenceModel::New(Foam::G eometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libincompressibleTurbulenceModel.so" #11 in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/pisoFoam" #12 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #13 in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/pisoFoam" Floating point exception (core dumped) Any of you guys recognize this error and the reason for it? |
How does your k and epsilon initial settings look, any chance they are initialized to zero? If so change it to something non-zero.
I don't think so. I have posted my k & epsilon below located in the /0 folder. Doesn't it look OK?
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object k; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0.00325; boundaryField { inlet { type fixedValue; value uniform 0.00325; } outlet { type fixedValue; value uniform 0.00325; } bot_cyl_wall { type fixedValue; value uniform 0; } upper_cyl_wall { type fixedValue; value uniform 0; } bot_symmetry { type fixedValue; value uniform 0; } upper_symmetry { type fixedValue; value uniform 0; } frontAndBackPlanes { type empty; } } // ************************************************** *********************** // /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object epsilon; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -3 0 0 0 0]; internalField uniform 0.000765; boundaryField { inlet { type fixedValue; value uniform 0.000765; } outlet { type fixedValue; value uniform 0.000765; } bot_cyl_wall { type fixedValue; value uniform 0; } upper_cyl_wall { type fixedValue; value uniform 0; } bot_symmetry { type fixedValue; value uniform 0; } upper_symmetry { type fixedValue; value uniform 0; } frontAndBackPlanes { type empty; } } // ************************************************** *********************** // |
