Vortex-Breakdown and BC at diffusor outlet
Hi all,
i am simulating a twisted flow field in a diffuser geometry. In ANSYS I get the vertex-breakdown effect but with OF not. I used the inletOutlet BC for U and T and set a fixedValue pressure at the outlet. Could it possible that I have to extend the outlet with a normal pipe ? In ANSYS we do so but I thought with the inletOutlet BC its possible to do it without that pipe. Tobi |
Hello Tobi,
I guess you are doing URANS? Or LES? I think you need to be more specific about the solver settings (fvSchemes and fvSolution). I remember that the onset of vortex breakdown is predicted too late if the solver is too dissipative (due to schemes or turbulence modeling). Regards, Hannes |
hi,
i am modelling with rans and k-epsilon, k-omega, and sst on a modified rhoSimpleFoam solver ... The schemes are gauss upwind and gauss linear couse other schemes are not converge. Its more a BC question what BC I set on the diffuser outlet couse there is the vortex breakdown too - in few regions. Or should I made an new outlet being away from the original outlet with the length of three x diffuser diameter ? Tobi |
