simpleFoam convergance problem
Like Tree6Likes
Old   October 12, 2013, 17:37
Default simpleFoam convergance problem
Daniel
Daniel_Khazaei will become famous soon enough
Hello foamers
I am trying to simulate a simple problem which includes a single straight pipe.
The flow is laminar and incompressible (steady state). As for the boundary condition, I am using:
inlet: pressureInlet 1333.2 Pa
outlet: pressureOutlet 0 Pa
I can easily get convergence on fluent in a minute. (residual order 1e-6)
Now when I try the same case in OpenFOAM (same mesh), it gives me a hard time to converge, as I think its going to take even a day to reach convergence tolerance.(simpleFoam solver) here is my case setup in OpenFOAM ( the case is attached):
Boundary condition:
|  \\    /   O peration     | Version:  1.5-dev                               |
|   \\  /    A nd           | Revision: 1736                                  |
|    \\/     M anipulation  | Web:      http://www.OpenFOAM.org               |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    FSI
        type            zeroGradient;
    OUTLET
        type            fixedValue;
        value           uniform 0;
    INLET
        type            fixedValue;
        value           uniform 1333.2;
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    FSI
        type            fixedValue;
        value           uniform (0 0 0);
    OUTLET
        type            zeroGradient;
    INLET
        type            zeroGradient;
Schemes:
|  \\    /   O peration     | Version:  1.3                                   |
|   \\  /    A nd           | Web:      http://www.openfoam.org               |
FoamFile
    version         2.0;
    format          ascii;
    root            "";
    case            "";
    instance        "";
    local           "";
    class           dictionary;
    object          fvSchemes;
ddtSchemes
    default steadyState;
gradSchemes
    default         cellMDLimited Gauss linear 0.5;
    grad(p)         cellMDLimited Gauss linear 0.5;
divSchemes
    default         none;
    div(phi,U)      Gauss linearUpwindV cellMDLimited Gauss linear 0.5;
    div((nuEff*dev(grad(U).T()))) Gauss linear corrected;
laplacianSchemes
    default         Gauss linear limited 0.5;
interpolationSchemes
    default         linear;
    interpolate(U)  linear;
snGradSchemes
    default         limited 0.5;
fluxRequired
    default         no;
    p;
Am I missing something obvious in OpenFOAM setup?
you can download the case here: http://www.rodfile.com/w4xt9xwxesqo
thank in advance
regards
Daniel_Khazaei is offline   Reply With Quote
Old   October 13, 2013, 13:52
Daniel
Residual plots have been attached.
File Type: jpg Screenshot from 2013-10-13 21:18:14.jpg (20.7 KB, 43 views)
File Type: jpg Screenshot from 2013-10-13 21:19:26.jpg (22.2 KB, 40 views)
Old   October 14, 2013, 07:52
Artem Shaklein
ARTem is on a distinguished road
Hello, Daniel.
I haven't calculated the right value of friction and corresponding velocity.
But I calculate max velocity restricted by laminar conditions (Re ~2000). So, velocity is about 0.6 m/s. I set this velocity as INLET boundary condition,with p=0 being set up at OUTLET, and I get average pressure at INLET about 0.1324 Pa. Looks similar to your value * 10^-4. May be there is some mistake in physical settings used?
Daniel_Khazaei likes this.
ARTem is offline   Reply With Quote
Old   October 14, 2013, 14:49
Daniel
Originally Posted by ARTem View Post
Hello, Daniel.
yes, actually there was a mistake in pressure input. I have used to work with compressible flow solvers where the dimension of p is [1 -1 -2 0 0 0 0].
but in incompressible solvers, its actually p/rho, so I should have used the value of 1.3332 instead of 1333.2
Now the only problem is that p does not go lower than a specific value (order of 10^-3), while the residual of U is acceptable (10^-8).
However, the result is the same as fluent.
Old   October 15, 2013, 04:42
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Can you show us the fvSolution-file?
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   October 15, 2013, 05:57
Daniel
yes, here you are:
| \\      /  F ield         | OpenFOAM Extend Project: Open Source CFD        |
|  \\    /   O peration     | Version:  1.6-ext                               |
|   \\  /    A nd           | Web:      www.extend-project.de                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
solvers
    p
        solver           PCG;
        preconditioner   DIC;
        tolerance        1e-06;
        relTol           0.01;
    U
        solver           PBiCG;
        preconditioner   DILU;
        tolerance        1e-05;
        relTol           0.1;
SIMPLE
    nNonOrthogonalCorrectors 2;
relaxationFactors
    p               0.3;
    U               0.7;
By the way, is there anyway to use a step function (function of time) as a boundary condition?
Old   October 15, 2013, 06:14
Philipp
Some ideas:
1) In gnuplot use "plot ... using ... every 3 ..." to get an accurate residual plot of your pressure. If you use 2 orthogonal correctors, you have 3 pressure values each iteration. You just want the first one to be plotted. Then, you can also plot all variables (u,p) in the same windows.
2) Are you sure this is the correct syntax for the relaxation factors? I always use:
relaxationFactors
    fields
        "p.*"           0.3;
        "nuSgs.*"       0.5;
    equations
        "U.*"           0.8;
        "k.*"           0.8;
        "omega.*"       0.8;
Having "p" in the "fields" subsection. For simpleFoam the "U.*" syntax isn't needed but for pimpleFoam. Also, this works for simpleFoam, too. So using this syntax it is easier to switch from simple to pimple.
2) Did you try to use a lower "relTol" for the pressure? Maybe you should use GAMG solver for "p" to save some time.
3) What numerical settings (discretization) did you use in Fluent? When I was comparing Fluent and OpenFoam it was always the case, that Fluent converges easily while OpenFoam had problems. Using limiters and bounding schemes at every possible location solved the problems. This lead me to the assumption that Fluent does the same...
Old   October 15, 2013, 11:55
Daniel
Some ideas:
relaxationFactors
    fields
        "p.*"           0.3;
        "nuSgs.*"       0.5;
    equations
        "U.*"           0.8;
        "k.*"           0.8;
        "omega.*"       0.8;
1) Thanks for the tip man now the life is easier
2) I think the difference we are seeing here is because of different versions of OpenFOAM ( I am using 1.6-ext)
3) Well GAMG is just faster in my case and does not help the convergence, not yet I will try to apply your suggestion.
3) in fluent: second order for pressure and second order upwind for momentum.
I have already tested cellMDLimited and cellLimited schemes, is there any other schemes that you have tried?
Old   October 15, 2013, 15:19
Daniel
well I have tested several options, but as you can see in the log file, pressure initial residual does change any more, could something be wrong with my mesh?
Time = 0.0199
DILUPBiCG:  Solving for Ux, Initial residual = 0.00024647, Final residual = 1.10217e-07, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 0.000111814, Final residual = 1.58072e-06, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 0.000111592, Final residual = 1.57813e-06, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.0106645, Final residual = 7.35506e-05, No Iterations 4
GAMG:  Solving for p, Initial residual = 0.010268, Final residual = 7.64759e-05, No Iterations 4
time step continuity errors : sum local = 1.40317e-07, global = 1.63051e-08, cumulative = 0.00461193
ExecutionTime = 39.56 s  ClockTime = 40 s
Time = 0.02
DILUPBiCG:  Solving for Ux, Initial residual = 0.000231742, Final residual = 1.03637e-07, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 0.000105065, Final residual = 1.4862e-06, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 0.000104864, Final residual = 1.48377e-06, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.0106366, Final residual = 7.3698e-05, No Iterations 4
GAMG:  Solving for p, Initial residual = 0.0102653, Final residual = 7.64477e-05, No Iterations 4
time step continuity errors : sum local = 1.40306e-07, global = 1.63289e-08, cumulative = 0.00461194
ExecutionTime = 40.2 s  ClockTime = 41 s
Time = 0.0201
DILUPBiCG:  Solving for Ux, Initial residual = 0.000217894, Final residual = 9.74417e-08, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 9.87491e-05, Final residual = 1.39652e-06, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 9.85661e-05, Final residual = 1.39436e-06, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.0106104, Final residual = 7.38322e-05, No Iterations 4
GAMG:  Solving for p, Initial residual = 0.0102628, Final residual = 7.64237e-05, No Iterations 4
time step continuity errors : sum local = 1.403e-07, global = 1.63521e-08, cumulative = 0.00461196
ExecutionTime = 40.38 s  ClockTime = 41 s
Time = 0.0202
DILUPBiCG:  Solving for Ux, Initial residual = 0.000204872, Final residual = 9.1616e-08, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 9.28788e-05, Final residual = 1.31221e-06, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 9.27076e-05, Final residual = 1.31033e-06, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.0105859, Final residual = 7.39572e-05, No Iterations 4
GAMG:  Solving for p, Initial residual = 0.0102604, Final residual = 7.64029e-05, No Iterations 4
time step continuity errors : sum local = 1.40297e-07, global = 1.63755e-08, cumulative = 0.00461198
ExecutionTime = 40.57 s  ClockTime = 41 s
Time = 0.0203
DILUPBiCG:  Solving for Ux, Initial residual = 0.000192629, Final residual = 8.61439e-08, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 8.74158e-05, Final residual = 1.23364e-06, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 8.72505e-05, Final residual = 1.232e-06, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.0105629, Final residual = 7.40766e-05, No Iterations 4
GAMG:  Solving for p, Initial residual = 0.0102582, Final residual = 7.63834e-05, No Iterations 4
time step continuity errors : sum local = 1.40295e-07, global = 1.63987e-08, cumulative = 0.00461199
ExecutionTime = 40.76 s  ClockTime = 41 s
Time = 0.0204
DILUPBiCG:  Solving for Ux, Initial residual = 0.000181116, Final residual = 8.10066e-08, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 8.22841e-05, Final residual = 1.16056e-06, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 8.21225e-05, Final residual = 1.15904e-06, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.0105413, Final residual = 7.41916e-05, No Iterations 4
GAMG:  Solving for p, Initial residual = 0.0102561, Final residual = 7.63641e-05, No Iterations 4
time step continuity errors : sum local = 1.40292e-07, global = 1.64205e-08, cumulative = 0.00461201
ExecutionTime = 40.95 s  ClockTime = 41 s
Time = 0.0205
DILUPBiCG:  Solving for Ux, Initial residual = 0.00017029, Final residual = 7.61809e-08, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 7.74076e-05, Final residual = 1.09227e-06, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 7.72516e-05, Final residual = 1.09076e-06, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.0105211, Final residual = 7.43008e-05, No Iterations 4
GAMG:  Solving for p, Initial residual = 0.0102542, Final residual = 7.63447e-05, No Iterations 4
time step continuity errors : sum local = 1.40286e-07, global = 1.644e-08, cumulative = 0.00461203
ExecutionTime = 41.14 s  ClockTime = 42 s
Time = 0.0206
DILUPBiCG:  Solving for Ux, Initial residual = 0.000160109, Final residual = 7.16425e-08, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 7.27476e-05, Final residual = 1.02781e-06, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 7.26005e-05, Final residual = 1.02631e-06, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.0105021, Final residual = 7.44023e-05, No Iterations 4
GAMG:  Solving for p, Initial residual = 0.0102523, Final residual = 7.63259e-05, No Iterations 4
time step continuity errors : sum local = 1.40279e-07, global = 1.64572e-08, cumulative = 0.00461204
ExecutionTime = 41.33 s  ClockTime = 42 s
Time = 0.0838
DILUPBiCG:  Solving for Ux, Initial residual = 4.71877e-10, Final residual = 4.71877e-10, No Iterations 0
DILUPBiCG:  Solving for Uy, Initial residual = 1.72695e-10, Final residual = 1.72695e-10, No Iterations 0
DILUPBiCG:  Solving for Uz, Initial residual = 1.72301e-10, Final residual = 1.72301e-10, No Iterations 0
GAMG:  Solving for p, Initial residual = 0.0102061, Final residual = 7.59525e-05, No Iterations 4
GAMG:  Solving for p, Initial residual = 0.0102235, Final residual = 7.60813e-05, No Iterations 4
time step continuity errors : sum local = 1.40268e-07, global = 1.67351e-08, cumulative = 0.00462262
ExecutionTime = 151.43 s  ClockTime = 153 s
Time = 0.0839
DILUPBiCG:  Solving for Ux, Initial residual = 4.64124e-10, Final residual = 4.64124e-10, No Iterations 0
DILUPBiCG:  Solving for Uy, Initial residual = 1.69857e-10, Final residual = 1.69857e-10, No Iterations 0
DILUPBiCG:  Solving for Uz, Initial residual = 1.69469e-10, Final residual = 1.69469e-10, No Iterations 0
time step continuity errors : sum local = 1.40268e-07, global = 1.67351e-08, cumulative = 0.00462263
ExecutionTime = 151.61 s  ClockTime = 154 s
Time = 0.084
DILUPBiCG:  Solving for Ux, Initial residual = 4.56497e-10, Final residual = 4.56497e-10, No Iterations 0
DILUPBiCG:  Solving for Uy, Initial residual = 1.67066e-10, Final residual = 1.67066e-10, No Iterations 0
DILUPBiCG:  Solving for Uz, Initial residual = 1.66685e-10, Final residual = 1.66685e-10, No Iterations 0
time step continuity errors : sum local = 1.40268e-07, global = 1.67351e-08, cumulative = 0.00462265
ExecutionTime = 151.77 s  ClockTime = 154 s
Old   October 16, 2013, 04:26
Philipp
Hey,
The mesh looks really coarse. Can you tell us the diameter of the pipe and the inlet velocity? I read, that for such systems it is better to have a velocity inlet and a pressure outlet - not two pressure b.c. like you have. But this is so simple, it should run as well with two pressure b.c...
Are you sure this is laminar?
Old   October 16, 2013, 05:08
Daniel
Hey,
Well, here are the details:
1) the diameter of the pipe is 10 mm
2) the length of the tube is 50 mm
3) The pressure at the inlet of the tube is 1333.2 Pa ( I am using p/rho=1.3332 as a inlet pressure )
Now I am using the totalPressure boundary condition for inlet, like fluent.
4) I have 0 Pa pressure at the outlet.
That was the initial mesh, so first I have tried to test it on fluent and when there was no problem, I have decided to test it on OpenFOAM.
I am using these value according to the paper I have.
Old   October 16, 2013, 05:12
Philipp
1) Can you upload the .msh file somewhere?
2) Are you 100% sure you use the same b.c. and viscosity as fluent?
Old   October 16, 2013, 05:30
Daniel
1) here you are: http://www.rodfile.com/w4dsnlx58l1o
2) I am pretty sure, because values of both simulations are almost the same with a little difference in pressure!
fluent: dynamic viscosity = 0.003 and density = 1000
pressure inlet= total Gage pressure = 1333.2 Pa
OpenFOAM: kinematic viscosity = 3e-6
pressure inlet= total pressure = 1.3332 [m^2/s^2] (p/rho)
Old   October 16, 2013, 07:44
Philipp
I use
ddtSchemes
gradSchemes
    grad(U)         cellMDLimited Gauss linear 1.0;
    grad(p)         cellLimited Gauss linear 1.0;
divSchemes
    default         none;
    div(phi,U)      bounded Gauss linearUpwind grad(U);
    div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
    default         linear;
snGradSchemes
    default         none;
fluxRequired
    default         no;
    p;
It seems to converge pretty slow, but it does.
Old   October 16, 2013, 08:22
Daniel
It seems that, I can not use "bounded Gauss linearUpwind grad(U)" scheme in 1.6-ext, I get the following error:
unknown convection scheme bounded
Valid convection schemes are :
3
explicit
Gauss
off
Old   October 16, 2013, 08:23
Philipp
Ok, try without it?
Why don't you install the most recent version?
Old   October 16, 2013, 08:40
Daniel
Ok, try without it?
yes, I have tried without that scheme:
Gauss linearUpwindV cellMDLimited Gauss linear 1.0;
But As I can see in your residual plot, the pressure residual drops much faster than others, but I am still on the order of 10^-3 after 2000 iteration.
can you upload the case you have used?
thanks for your attention
regards
I am trying to simulate a Fluid-solid interaction and that solver is available in OpenFOAM-1.6-ext.
At first I am trying to make sure that everything is OK with Fluid solver.
Old   October 16, 2013, 08:59
Philipp
Here it is
newCase.zip
Old   October 16, 2013, 09:06
Daniel
Here it is
Attachment 26112
Meanwhile I have setup my case on 22x version and the solution has converged in less than 200 iterations.
I have also changed U solver to smoothSolver.
results are similar to fluent.
I will upload the case.
22x version: http://www.rodfile.com/f6dwibedvb05
regards
Old   October 16, 2013, 09:42
Philipp
Great to see it worked.
interFoam vs. simpleFoam channel flow comparison DanM OpenFOAM Running, Solving & CFD 12 January 31, 2020 15:26
a problem with simpleFoam fring OpenFOAM Bugs 1 January 9, 2013 12:05
Problem running simpleFoam with kOmegaSST turbulence model matzbanni OpenFOAM Running, Solving & CFD 5 November 3, 2012 06:45
SimpleFoam convergen problem maolongliu OpenFOAM 7 August 13, 2010 10:17
Free Surface Problem - Convergance Toby FLUENT 0 July 2, 2008 23:16
