-   -   Boundary conditions: Asymmetric plane diffuser, k-omega SST, low-Re (http://www.cfd-online.com/Forums/openfoam-solving/106968-boundary-conditions-asymmetric-plane-diffuser-k-omega-sst-low-re.html)
Krischan September 13, 2012 11:57
Hey everyone,
I'm trying to simulate the flow through an asymmetric plane diffuser (ERCOFTAC Testcase) to compare the results from the simulation against the experimental results as well as results obtained from a simulation with Ansys CFX.
I'm using k-omega SST as turbulence model together with a low Re-mesh in OF 2.1.1.
However, simulation results aren't as expected, as the flow separation is largely overpredicted, so I was wondering if I got the boundary conditions right for this kind of simulation (especially for k, omega and nut). Choosing the settings gave me a hard time, maybe there's still something wrong with it.
The contents of the files is posted below, any help is much appreciated.
Thanks in advance,
Krischan
k:
#include        "include/initialConditions"
dimensions      [0 2 -2 0 0 0 0];
internalField  uniform $turbulentKE;
boundaryField
    WALLUP
        type fixedValue;
        value uniform 1e-11;
    WALLD
        type fixedValue;
    OUTLET
      type zeroGradient;
    INLET
        type            turbulentIntensityKineticEnergyInlet;
        intensity      0.05;
        U              U;
        phi            phi;
        value          uniform 0.05;
    #include    "include/symPlanes"
omega:
dimensions      [0 0 -1 0 0 0 0];
internalField  uniform $turbulentOmega;
boundaryField
    WALLUP
        type            fixedValue;
        value            uniform 1e09;
    WALLD
        type            fixedValue;
        value            uniform 1e09;
    OUTLET
        type            zeroGradient;
    INLET
        type            fixedValue;
        value          $internalField;
nut:
dimensions      [0 2 -1 0 0 0 0];
internalField  uniform 0;
boundaryField
    INLET
        type            calculated;
        value          uniform 0;
    OUTLET
        type            zeroGradient;
    WALLUP
        type            nutLowReWallFunction;
        value          uniform 0;
    WALLD
        value          uniform 0;
p:
internalField  uniform $pressure;
boundaryField
    INLET
          type            zeroGradient;
    OUTLET
        type            fixedValue;
    WALLD
        type            zeroGradient;
    WALLUP
        type            zeroGradient;
U:
dimensions      [0 1 -1 0 0 0 0];
internalField  uniform $flowVelocity;
boundaryField
    INLET
        type            fixedValue;
        value          uniform $flowVelocity;
    OUTLET
        type            zeroGradient;
    WALLD
        type            fixedValue;
        value          uniform (0 0 0);
    WALLUP
        type            fixedValue;
initial conditions include file:
flowVelocity        (54.83 0 0);
pressure            0; //101325;
turbulentKE          11.2737;
turbulentOmega      72962;
#inputMode          merge
Krischan September 14, 2012 07:45
Never mind - boundary conditions are correct, after changing the solver parameters in fvSolution (tolereance and reltol), everything works as expected.
Jonathan September 16, 2012 17:17
Hi Krischan,
glad you got your problem sorted! well done!
I just had a quick question regarding your set up! I see you need to use a wall function for nut even though you are using a low Re approach for k-omega ... i was wondering whether you knew why exactly you need to do this? i have seen this is the way you need to go, but still cant figure out why you need to use a WF at all if you are using a low Re implementation for the turbulence model and you have specified k / omega as per guidelines for a low Re implementation as you had done? Nut is a calculated from k / omega as we know, so why do we need a BC / wall function for it (nut) anyway?
many thanks for any help here!
cheers
Jonathan
