Checkerboarding problem in LES
Old   June 9, 2009, 05:35
Default Checkerboarding problem in LES
Matteo Baldi
Matteo85 is on a distinguished road
I've been testing LES/DES models using the central differencing scheme for the convective term of the momentum equation, on some test-cases in which the flow encounters a bluff body (square cylinder; ribs in a channel). Despite adopting configurations and grids very similar to the ones employed in some works present in literature, the simulations I've been running suffer from the well-known problem of Checkerboarding, that presents itself in the velocity field (it persists even averaging in time) but not in the pressure field.
This frequent presence of checkerboarding is quite strange, considering that the central scheme employs the interpolation of Rie&Chow, which is just meant to avoid the problem.
I'd like to know if any of you has experienced such difficulties in using the central difference scheme in OF.
Thank you very much,
Matteo
Matteo85 is offline   Reply With Quote
Old   June 10, 2009, 05:41
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
This is tour third posting in a new thread since yesterday with the exact same wording. It will definitely not help you to get an answer, and furthermore your are cluttering the Forum with useless thread, so people following you, will have less change to find any relevant information.
Best regards,
Niels
ngj is offline   Reply With Quote
Old   June 11, 2009, 02:30
Matteo Baldi
Dear Niels,
I perfectly know how to behave correctly without your help ("your", not "tour"..);
if you look carefully my posts are 2, not 3, and the 2nd is a correction of the 1st, that's not just the same wording.. I did write the 1st thread twice, but only because I checked and the thread didn't appear among the new ones.
I'll be waiting for some useful contribution
My kindest regards.
Matteo
Old   September 15, 2012, 22:15
Tarak
Tarak is on a distinguished road
Hii Matteo,
I'm facing the same problem too, but I'm using linearUpwind as the convection scheme. Did you find any solution to your problem?
Thanks,
Tarak
Tarak is offline   Reply With Quote
central difference, checkerboarding, les
Differences between a laminar code and a les one ben Main CFD Forum 9 February 16, 2005 23:40
LES on two phase flow Li Yang Main CFD Forum 0 May 12, 2004 08:10
Some Questions about LES. Bin Li Main CFD Forum 2 February 20, 2004 09:58
LES problem Jose FLUENT 5 September 29, 2003 05:04
problem while looping over cells in LES Jimmy FLUENT 0 September 5, 2002 15:33
