Boundary conditions: Asymmetric plane diffuser, k-omega SST, low-Re
Old   September 13, 2012, 11:57
Default Boundary conditions: Asymmetric plane diffuser, k-omega SST, low-Re
Christian
Krischan is on a distinguished road
Hey everyone,
I'm trying to simulate the flow through an asymmetric plane diffuser (ERCOFTAC Testcase) to compare the results from the simulation against the experimental results as well as results obtained from a simulation with Ansys CFX.
I'm using k-omega SST as turbulence model together with a low Re-mesh in OF 2.1.1.
However, simulation results aren't as expected, as the flow separation is largely overpredicted, so I was wondering if I got the boundary conditions right for this kind of simulation (especially for k, omega and nut). Choosing the settings gave me a hard time, maybe there's still something wrong with it.
The contents of the files is posted below, any help is much appreciated.
Thanks in advance,
Krischan
k:
#include        "include/initialConditions"
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform $turbulentKE;
boundaryField
    WALLUP
        type fixedValue;
        value uniform 1e-11;
    WALLD
        type fixedValue;
    OUTLET
      type zeroGradient;
    INLET
        type            turbulentIntensityKineticEnergyInlet;
        intensity       0.05;
        U               U;
        phi             phi;
        value           uniform 0.05;
    #include    "include/symPlanes"
omega:
dimensions      [0 0 -1 0 0 0 0];
internalField   uniform $turbulentOmega;
boundaryField
    WALLUP
        type            fixedValue;
        value             uniform 1e09;
    WALLD
        type            fixedValue;
        value             uniform 1e09;
    OUTLET
        type            zeroGradient;
    INLET
        type            fixedValue;
        value           $internalField;
nut:
dimensions      [0 2 -1 0 0 0 0];
internalField   uniform 0;
boundaryField
    INLET
        type            calculated;
        value           uniform 0;
    OUTLET
        type            zeroGradient;
    WALLUP
        type            nutLowReWallFunction;
        value           uniform 0;
    WALLD
        value           uniform 0;
p:
internalField   uniform $pressure;
boundaryField
    INLET
          type            zeroGradient;
    OUTLET
        type            fixedValue;
    WALLD
        type            zeroGradient;
    WALLUP
        type            zeroGradient;
U:
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform $flowVelocity;
boundaryField
    INLET
        type            fixedValue;
        value           uniform $flowVelocity;
    OUTLET
        type            zeroGradient;
    WALLD
        type            fixedValue;
        value           uniform (0 0 0);
    WALLUP
        type            fixedValue;
initial conditions include file:
flowVelocity         (54.83 0 0);
pressure             0; //101325;
turbulentKE          11.2737;
turbulentOmega       72962;
#inputMode           merge
Krischan is offline   Reply With Quote
Old   September 14, 2012, 07:45
Christian
Never mind - boundary conditions are correct, after changing the solver parameters in fvSolution (tolereance and reltol), everything works as expected.
Old   September 16, 2012, 17:17
Jonathan is on a distinguished road
Hi Krischan,
glad you got your problem sorted! well done!
I just had a quick question regarding your set up! I see you need to use a wall function for nut even though you are using a low Re approach for k-omega ... i was wondering whether you knew why exactly you need to do this? i have seen this is the way you need to go, but still cant figure out why you need to use a WF at all if you are using a low Re implementation for the turbulence model and you have specified k / omega as per guidelines for a low Re implementation as you had done? Nut is a calculated from k / omega as we know, so why do we need a BC / wall function for it (nut) anyway?
many thanks for any help here!
cheers
Jonathan
Jonathan is offline   Reply With Quote
symmetry boundary conditions in cfx lost.identity CFX 41 May 22, 2013 07:21
inlet boundary conditions newOFuser OpenFOAM 1 January 10, 2013 08:08
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
natural convection mehrdadeng CFX 10 February 25, 2011 05:25
Boundary conditions low Mach number flow lost.identity Main CFD Forum 0 November 28, 2010 04:44
