Limiting / Ranging values during calculation
Like Tree1Likes
  • 1 Post By fredo490
Old   September 22, 2012, 07:45
Default Limiting / Ranging values during calculation
HECKMANN Frédéric
fredo490 is on a distinguished road
Hello everyone,
Is there any function in openfoam to limit a value (density, x-velocity, y-velocity, pressure, ...) with upper and lower value at each iteration ?
I am thinking about something like the "Solution Control" + "Limits" that we can find in Fluent.
I am using the rhoPimpleFoam solver now. In my point of view, if I add a cell loop after the "solve", it will only patch the solution after all the iteration of the time step, right ?
Thank you in advance.
fredo490 is offline   Reply With Quote
Old   September 22, 2012, 07:59
HECKMANN Frédéric
For the density, there is something like this :
PIMPLE
    momentumPredictor yes;
    nOuterCorrectors 1;
    nCorrectors     2;
    nNonOrthogonalCorrectors 0;
    rhoMin          rhoMin [ 1 -3 0 0 0 ] 0.5;
    rhoMax          rhoMax [ 1 -3 0 0 0 ] 2.0;
But I can't find anything for the density and the velocity (in each axis)
Edit, this is present in the "fvSolution" file
parthigcar likes this.
limit, limitation, limits, range
Transfer output data as input for second calculation mannobot Main CFD Forum 3 December 7, 2018 09:37
MRF and Heat transfer calculation Susan YU FLUENT 0 June 2, 2010 08:46
Defining output as input for second calculation mannobot FLUENT 1 June 2, 2010 04:20
strange node values @ solid/fluid interface - help JB FLUENT 2 November 1, 2008 12:04
node values or cell values? aPpA FLUENT 0 November 10, 2006 08:56
