Home > Forums > OpenFOAM Running, Solving & CFD
buoyantBoussinesqSimpleFoam convergence problem.
Old   September 25, 2012, 10:56
Default buoyantBoussinesqSimpleFoam convergence problem.
Eskil Aursand
eskila is on a distinguished road
I am trying to get a buoyantBoussinesqSimpleFoam simulation with a k-eps turbulence model to converge, but it never does. The output states that the residuals are smaller than the SIMPLE tolerances, but it still doesn't stop.
Here is an example output:
DILUPBiCG:  Solving for Ux, Initial residual = 0.00776199, Final residual = 3.05559e-05, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 0.0033988, Final residual = 1.59953e-05, No Iterations 1
DILUPBiCG:  Solving for T, Initial residual = 0.000345836, Final residual = 1.40283e-05, No Iterations 1
DICPCG:  Solving for p_rgh, Initial residual = 0.0300916, Final residual = 0.0002878, No Iterations 15
time step continuity errors : sum local = 7.9083e-05, global = -1.09848e-05, cumulative = 0.00106109
DILUPBiCG:  Solving for epsilon, Initial residual = 0.000168969, Final residual = 2.31597e-06, No Iterations 1
DILUPBiCG:  Solving for k, Initial residual = 0.001979, Final residual = 3.89602e-05, No Iterations 1
Here is my fvSolution:
solvers
    p_rgh
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-08;
        relTol          0.01;
    "(U|T|k|epsilon|R)"
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-05;
        relTol          0.1;
SIMPLE
    nNonOrthogonalCorrectors 0;
    pRefCell        0;
    pRefValue       0;
    residualControl
        p_rgh           1e-2;
        U               1e-4;
        T               1e-2;
        // possibly check turbulence fields
        "(k|epsilon|omega)" 1e-3;
relaxationFactors
    fields
        p_rgh           0.5;
    equations
        U               0.2;
        T               0.5;
        "(k|epsilon|R)" 0.5;
As seen the final residuals are smaller than the tolerances set in residualControl. If i set the SIMPLE tolerances to 1e-1 it converges however, but I don't understand why they have to be so low.
If it matters: The case is 2D with a cold circle in the center, hot walls on the sides and below, and an insulating boundary above. Gravity points down. Solver is buoyantBoussinesqSimpleFoam.
Any help and tips will be appreciated!
eskila is offline   Reply With Quote
Old   August 5, 2014, 01:25
Default Exact same problem
Srivathsan N
Sherlock_1812 is on a distinguished road
Hi all,
I am facing a similar problem. My last time step residuals are
DILUPBiCG:  Solving for Ux, Initial residual = 1.13167e-09, Final residual = 1.13167e-09, No Iterations 0
DILUPBiCG:  Solving for Uy, Initial residual = 3.7544e-10, Final residual = 3.7544e-10, No Iterations 0
DILUPBiCG:  Solving for Uz, Initial residual = 0.000492656, Final residual = 4.17232e-06, No Iterations 1
DILUPBiCG:  Solving for T, Initial residual = 9.9924e-06, Final residual = 9.9924e-06, No Iterations 0
DICPCG:  Solving for p_rgh, Initial residual = 1.05994e-08, Final residual = 7.33015e-09, No Iterations 1
time step continuity errors : sum local = 3.02676e-11, global = 9.96442e-20, cumulative = -1.45381e-16
However my fvSolution file reads as follows,
solvers
    p_rgh
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-08;
        relTol          0.01;
    "(U|T|k|epsilon|R)"
        solver          PBiCG;
        tolerance       1e-05;
        relTol          0.1;
SIMPLE
    pRefCell        0;
    pRefValue       0;
    residualControl
        p_rgh           1e-4;
        U               1e-5;
        T               1e-2;
The residuals also seem to fluctuate very much except temperature that seems to flatten out.
Q: Why hasn't the solution converged even though the SIMPLE tolerances have been met?
Any help would be great!
Regards,
Srivaths
Sherlock_1812 is offline   Reply With Quote
Old   August 20, 2014, 08:59
Cong
wc34071209 is on a distinguished road
I remember I was faced with the same problems with the buoyantSimpleFoam. The residual never goes down below 1e-6. I had no idea why.
wc34071209 is offline   Reply With Quote
Old   August 20, 2014, 09:16
Srivathsan N
I have tried increasing the pseudo time step in the controlDict. There are no oscillation if I do that but the solution diverges after a few iterations. Again, have no idea why.
I'm using OF 2.2.2, by the way.
Regards,
Srivaths
Thread Tools
Trackbacks are On
convergence problem when use pisoFoam, LES for wind tunnel case Forrest_Lei OpenFOAM 3 July 19, 2011 06:00
convergence problem commonyue Main CFD Forum 1 December 1, 2009 04:54
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
3D Fluid Flow Convergence problem Emily FLUENT 2 March 21, 2007 23:18
Non Convergence of 3D Heat transfer cfd problem Balraj Main CFD Forum 3 December 9, 2004 01:24
