Velocity Oscillations in PisoFoam
Old   October 5, 2012, 21:43
Default Velocity Oscillations in PisoFoam
David Chiba
cheeba is on a distinguished road
Hello -
I am getting spurious
Uz oscillations when using PisoFoam. To explore the problem I have input an initial field that oscillates from a positive to a negative value at each consecutive depth. When I let the run go nothing happens to the velocities - they stay there stably (even though from a physical standpoint there is lots of divergence which should not occur). The pressure field also oscillates. In the attached png I have shown a pictures of a vertical slice of my grid for pressure and vertical velocity at time =100 as well as my fvSchemes. I need to somehow change my discretization schemes so that the oscillations go away so they do not occur during my simulation.
Thanks is advance for the help!
cheeba is offline   Reply With Quote
fvschemes, openfoam 2.1.0, oscillations, pisofoam
Plotting Radial Velocity and Tangential Velocity in CFD Post ashtonJ CFX 5 July 13, 2015 02:49
help with UDF for contact angle based on contact line velocity gandesk Fluent UDF and Scheme Programming 14 October 29, 2012 13:58
Velocity in Porous medium : HELP! HELP! HELP! Kali Sanjay Phoenics 0 November 6, 2006 06:10
velocity more than INLET velocity neu FLUENT 3 May 13, 2003 04:56
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
