October 4, 2012, 11:49 |
Wind profile boundary layer problem
Rafael Valenzuela Musura
Hi everyone I'm simulationg a 3D delta wing in atmospheric conditions. I'm using the simpleFoam-motorBike configuration and everything seems to be ok, but the only problem I have is that the boundary layer formed over the ground isn't constant. It seems to me that when the patch of "inlet" start blowing it generates a boundary separation and that makes the wind profile not to be constant as I need.
Do anyone knows how to implement an inlet wind profile boundary condition?, I've tried swak4Foam to implement the groovy BC but I fail trying to make it work. Please help me, I'm quite desperate here. Thanks |
October 5, 2012, 10:42 |
Eloïse
Hi Rafael,
Are you aware of the wall function problems when simulating ABL flows? Blocken described it in some papers such as this one http://www.sciencedirect.com/science...5223100600834X If you don't adapt your mesh and wall function parameters to ABL flow, you will have large variations of your profile through your domain. I hope this already helps a bit. I've never used swak4Foam but I'm planning to test it soon. Let me know if you manage to get it to work! Regards, Eloïse |
boundary, inlet, profile, wind |
GAMBIT meshing problem for boundary layer | Falah | FLUENT | 2 | November 30, 2020 14:16 |
Questions about Boundary Layer Thickness and Turbulence Models | famerfamer | STAR-CCM+ | 3 | July 12, 2012 09:47 |
[GAMBIT] 3D boundary layer and meshing problem in GAMBIT 2.4.6 | prashanthreddyh | ANSYS Meshing & Geometry | 1 | December 20, 2011 00:35 |
[snappyHexMesh] Problem with the boundary layer using snappyHexMesh | LVDH | OpenFOAM Meshing & Mesh Conversion | 13 | March 15, 2010 10:42 |
