-   -   what is the meaning of this?!??!!? (http://www.cfd-online.com/Forums/openfoam-solving/107746-what-meaning.html)
adambarfi October 5, 2012 12:21
Hi everybody
I'm modeling a rotating square between water and air. when I run my model, the following messages appeared in my terminal:
solidBodyMotionFunctions::rotatingMotion::transformation(): Time = 0.0827406 transformation: ((0 0 0) (-0.856565 (0 0 0.51604)))
Execution time for mesh.update() = 0.05 s
time step continuity errors : sum local = 5.19359e-14, global = 1.91199e-15, cumulative = 1.45354e-06
GAMGPCG:  Solving for pcorr, Initial residual = 1, Final residual = 3.28882e-06, No Iterations 9
time step continuity errors : sum local = 3.27857e-15, global = -4.81172e-17, cumulative = 1.45354e-06
MULES: Solving for alpha1
Liquid phase volume fraction = 0.129117  Min(alpha1) = -3.3351e-36  Max(alpha1) = 0.999977
Liquid phase volume fraction = 0.129169  Min(alpha1) = -3.33127e-36  Max(alpha1) = 0.999977
Liquid phase volume fraction = 0.12922  Min(alpha1) = -3.32675e-36  Max(alpha1) = 0.999977
GAMG:  Solving for p_rgh, Initial residual = 0.0226012, Final residual = 0.000126703, No Iterations 3
time step continuity errors : sum local = 1.35142e-09, global = 7.04088e-12, cumulative = 1.45355e-06
GAMGPCG:  Solving for p_rgh, Initial residual = 0.00713841, Final residual = 5.44584e-09, No Iterations 6
time step continuity errors : sum local = 5.81134e-14, global = 2.97304e-16, cumulative = 1.45355e-06
smoothSolver:  Solving for epsilon, Initial residual = 0.00084478, Final residual = 7.54014e-08, No Iterations 3
smoothSolver:  Solving for k, Initial residual = 0.000782825, Final residual = 2.30447e-07, No Iterations 3
ExecutionTime = 305.2 s  ClockTime = 306 s
Interface Courant Number mean: 0.0379477 max: 0.490161
Courant Number mean: 0.248671 max: 0.499417
deltaT = 7.19143e-05
Time = 0.0828125
solidBodyMotionFunctions::rotatingMotion::transformation(): Time = 0.0828125 transformation: ((0 0 0) (-0.857728 (0 0 0.514103)))
Execution time for mesh.update() = 0.04 s
time step continuity errors : sum local = 5.86878e-14, global = 2.49004e-16, cumulative = 1.45355e-06
can anybody help me?
what is the meaning of this message:
thank you
ata October 6, 2012 07:34
Hi
I think
sum local is absolute summation of continuty error in all CVs at present time step.
global is summation of continuty error in all CVs at present time stem and
cumulative is summation of global continuity errors from the first time step.
adambarfi October 6, 2012 12:25
Originally Posted by ata (Post 385197)
Hi
I think
thank you Ata for your reply.
but does this error has any influence on my results? I think the answer is: No, It doesn't.
alberto October 6, 2012 20:44
Yes, it does :D
The solver reports the error for informative purposes, as a measure of how good your solution is. You want this error to be as close to machine precision as possible.
adambarfi October 8, 2012 02:46
Originally Posted by alberto (Post 385245)
Yes, it does :D
thank you Alberto,
but what do you think about the source of below error:
DICPCG:  Solving for p, Initial residual = 1, Final residual = 6.72375e-08, No Iterations 62
time step continuity errors : sum local = 4.77002e+25, global = -9.93552e+15, cumulative = -9.93552e+15
Model mode 1
#0  Foam::error::printStack(Foam::Ostream&) in "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2  Uninterpreted:
#3  Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#4  Foam::fvMatrix<Foam::SymmTensor<double> >::solve(Foam::dictionary const&) in "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libviscoelasticTransportModels.so"
#5  Foam::fvMatrix<Foam::SymmTensor<double> >::solve() in "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libviscoelasticTransportModels.so"
#6  Foam::Giesekus::correct() in "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libviscoelasticTransportModels.so"
#7  Foam::multiMode::correct() in "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libviscoelasticTransportModels.so"
#8  Foam::viscoelasticModel::correct() in "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libviscoelasticTransportModels.so"
 in "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/bin/BuoyantBoussinesqViscoelasticFluidFoam"
#10  __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
#11
Floating point exception
I'm so confused. please help me.
my solver is the viscoelasticFluidFoam that I made some changes to it for solving natural convection. when I ran it, after some iterate the above error appeared.
anyone is here can help me????
thanks.
ata October 8, 2012 05:23
Hi
If I want to speak general your schemes and/or methods for solving system of linear equations and/or their adjustments are improper.
adambarfi October 8, 2012 06:12
Originally Posted by ata (Post 385469)
Hi
hi ata,.
can you tell me the details? I'm about two weeks that staying behind this error.
thank you.
EricKl. September 12, 2013 15:24
Hello, I am trying to simulate a runoff, but I'm having the following problem:
What can I do?
Thanks
| \\      /  F ield        | OpenFOAM Extend Project: Open source CFD        |
|  \\    /  O peration    | Version:  1.6-ext                              |
|  \\  /    A nd          | Web:      www.extend-project.de                |
|    \\/    M anipulation  |                                                |
Build  : 1.6-ext-e61a8f0a3194
Exec  : viscoelasticInterFoam
Date  : Sep 12 2013
Time  : 16:23:40
Host  : administrador-desktop
PID    : 10189
Case  : /home/administrador/tutorials/viscoelastic/VIFErick/Escoamento
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 0
// using new solver syntax:
U
    solver          PBiCG;
    preconditioner
        preconditioner  DILU;
    minIter        0;
    maxIter        1000;
    tolerance      1e-06;
    relTol          0;
taufirst
    solver          BiCGStab;
    preconditioner
        preconditioner  Cholesky;
    minIter        0;
    maxIter        1000;
    tolerance      1e-06;
    relTol          0;
tau
    solver          BiCGStab;
    preconditioner
    minIter        0;
    maxIter        1000;
    tolerance      1e-06;
    relTol          0;
Reading g
Reading transportProperties
Reading field pd
Reading field alpha
Reading field U
Calculating field g.h
Selecting viscoelastic model Giesekus
time step continuity errors : sum local = 6.31081e-07, global = -6.31081e-07, cumulative = -6.31081e-07
--> FOAM FATAL ERROR:
Continuity error cannot be removed by adjusting the outflow.
Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow.
Specified mass inflow  : 7.65133e-08
Specified mass outflow  : 0
Difference              : 7.65133e-08
Adjustable mass outflow : 0
    From function adjustPhi
    surfaceScalarField& phi,
    const volVectorField& U,
    const volScalarField& p
    in file cfdTools/general/adjustPhi/adjustPhi.C at line 141.
FOAM exiting
Bernhard September 13, 2013 02:39
Please check the velocity boundary conditions. What are the velocity boundary conditions in your case?
EricKl. September 13, 2013 10:53
Thanks for reply
My code for velocity is:
| \\      /  F ield        | OpenFOAM Extend Project: Open Source CFD        |
FoamFile
    version    2.0;
    format      ascii;
    class      volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField  uniform (0 0 0);
boundaryField
    inlet
        type            fixedValue;
        value          uniform (0.01868 0 0);
    fixedWalls
        type            fixedValue;
        value          uniform (0 0 0);
    frontAndBack
        type            empty;
    outlet
        type            zeroGradient;
    simetry
        type            symmetryPlane;
    atmosphere
        type            pressureInletOutletVelocity;
        phi            phi;
When I run potentialFoam, the program gives me
Exec  : potentialFoam
Date  : Sep 13 2013
Time  : 11:55:07
PID    : 16452
nProcs : 1
Create time
U
    solver          PBiCG;
    preconditioner
    minIter        0;
    maxIter        1000;
    tolerance      1e-06;
    relTol          0;
taufirst
    solver          BiCGStab;
    preconditioner
    minIter        0;
    maxIter        1000;
    tolerance      1e-06;
    relTol          0;
tau
    solver          BiCGStab;
    preconditioner
    minIter        0;
    maxIter        1000;
    tolerance      1e-06;
    relTol          0;
Reading field p
Reading field U
--> FOAM FATAL IO ERROR:
keyword SIMPLE is undefined in dictionary "/home/administrador/tutorials/viscoelastic/VIFErick/Escoamento/system/fvSolution"
file: /home/administrador/tutorials/viscoelastic/VIFErick/Escoamento/system/fvSolution at line 21.
    From function dictionary::subDict(const word& keyword) const
    in file db/dictionary/dictionary.C at line 457.
FOAM exiting
I tried move and ajust velocity, but the errors continues
I'm really lost
