Home > Forums > OpenFOAM Running, Solving & CFD
Rotating a square between water and air!!! please help me
Old   October 5, 2012, 15:27
Default Rotating a square between water and air!!! please help me
adambarfi's Avatar
Mostafa Mahmoudi
adambarfi is on a distinguished road
Send a message via Yahoo to adambarfi Send a message via Skype™ to adambarfi
Hi everybody
I'm trying to simulate a rotating square between water and air. but when I ran it, whole of my model started to rotate. I want to rotate only the square.
I'm using interDyMFoam and my dynamicMeshDict is as follow:
dynamicFvMesh   solidBodyMotionFvMesh;
motionSolverLibs ( "libfvMotionSolvers.so" );
solidBodyMotionFvMeshCoeffs
//    cellZone        z0;
    solidBodyMotionFunction  rotatingMotion;
    rotatingMotionCoeffs
        CofG        (1.5 1 0);
        radialVelocity (0 0 600); // deg/s
and my topoSet is:
actions
        name    c0;
        type    cellSet;
        action  new;
        source  boxToCell;
        sourceInfo
            box (1 0.75 0) (2 1.25 1);
        name    c0;
        type    cellSet;
        action  invert;
anybody know how can where is my mistake???
thank you
adambarfi is offline   Reply With Quote
Old   October 6, 2012, 13:16
adambarfi's Avatar
Mostafa Mahmoudi
hi again,
I approached some success but still there is another error!!!
I remove my box from the mesh, so I have just a rectangular. instead I create the box with topoSet:
actions
        name    c0;
        type    cellSet;
        action  new;
        source  boxToCell;
        sourceInfo
        name    c0;
        type    cellZoneSet;
        action  new;
        source  setToCellZone;
        sourceInfo
            set c0;
and create a MRFZones in constant:
1
    cellZone      c0;
        // Fixed patches (by default they 'move' with the MRF zone)
        nonRotatingPatches ();
        origin    origin [0 1 0 0 0 0 0]  (1.5 1 0);
        axis      axis   [0 0 0 0 0 0 0]  (0 0 1);
        omega     omega  [0 0 -1 0 0 0 0] 104.72;
and the dynamicMeshDict:
    cellZone        c0;
        CofG        (1.5 1 0);
        radialVelocity (0 0 360); // deg/s
when I ran it after some iterate the following errors appeared:
MULES: Solving for alpha1
Liquid phase volume fraction = 0.500578  Min(alpha1) = -3.18487e-13  Max(alpha1) = 1
--> FOAM Warning :
    From function Time::operator++()
    in file db/Time/Time.C at line 982
    Increased the timePrecision from 12 to 13 to distinguish between timeNames at time 0.00823197
GAMG:  Solving for p_rgh, Initial residual = 0.322617, Final residual = 0.00186789, No Iterations 2
time step continuity errors : sum local = 4.29278e-35, global = -6.25487e-38, cumulative = -1.63983e-12
GAMGPCG:  Solving for p_rgh, Initial residual = 0.00377318, Final residual = 2.5956e-09, No Iterations 7
time step continuity errors : sum local = 7.89155e-41, global = 1.65503e-42, cumulative = -1.63983e-12
ExecutionTime = 11.66 s  ClockTime = 11 s
Interface Courant Number mean: 1.23621e-14 max: 1.90583e-10
Courant Number mean: 1.71623e-13 max: 0.498603
deltaT = 7.02395e-15
Time = 0.008231967303353
solidBodyMotionFunctions::rotatingMotion::transformation(): Time = 0.00823197 transformation: ((0.0537059 -0.0762125 0) (0.999666 (0 0 0.0258586)))
Execution time for mesh.update() = 0.03 s
time step continuity errors : sum local = 8.40744e-15, global = 1.25511e-32, cumulative = -1.63983e-12
GAMGPCG:  Solving for pcorr, Initial residual = 1, Final residual = 6.72386e-06, No Iterations 7
time step continuity errors : sum local = 8.71776e-15, global = 2.16723e-24, cumulative = -1.63983e-12
GAMG:  Solving for p_rgh, Initial residual = 0.320425, Final residual = 0.00185845, No Iterations 2
time step continuity errors : sum local = 2.11983e-35, global = -3.2799e-38, cumulative = -1.63983e-12
GAMGPCG:  Solving for p_rgh, Initial residual = 0.00373144, Final residual = 2.53592e-09, No Iterations 7
time step continuity errors : sum local = 3.82037e-41, global = 8.38953e-43, cumulative = -1.63983e-12
ExecutionTime = 11.97 s  ClockTime = 12 s
Interface Courant Number mean: 6.19464e-15 max: 9.70649e-11
Courant Number mean: 8.60789e-14 max: 0.499017
deltaT = 3.51889e-15
Time = 0.008231967303356
Execution time for mesh.update() = 0.04 s
time step continuity errors : sum local = 4.36747e-15, global = -2.00572e-32, cumulative = -1.63983e-12
GAMGPCG:  Solving for pcorr, Initial residual = 1, Final residual = 5.83869e-06, No Iterations 8
time step continuity errors : sum local = 4.66468e-15, global = 1.53072e-22, cumulative = -1.63983e-12
GAMG:  Solving for p_rgh, Initial residual = 0.320982, Final residual = 0.00186428, No Iterations 2
#0  Foam::error::printStack(Foam::Ostream&) in "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2  Uninterpreted:
#3  Foam::inv(Foam::Field<Foam::SymmTensor<double> >&, Foam::UList<Foam::SymmTensor<double> > const&) in "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
 in "/home/mostafa/OpenFOAM/OpenFOAM-2.1.0/platforms/linuxGccDPOpt/bin/interDyMFoam"
#7  __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
Floating point exception
when I execute the paraFoam, there was just a rectangular that at its center some meshes have been rotating which they were what I defined in topoSet. but after a little the some meshes expand and some compact. there wasn't any thing like remeshing in FLUENT!!!!
anybody knows how can I solve this problem? and how can I have a separated rotating box instead of a moving mesh that has no boundary with its surrounding fluids?
please help me.
thank you.
Old   October 8, 2012, 02:49
adambarfi's Avatar
Mostafa Mahmoudi
anyone has any idea?!?!?!? please.
Old   October 10, 2012, 05:10
adambarfi's Avatar
Mostafa Mahmoudi
actually, there is nobody to help me?!! I just want to rotate a square in a fluid.
does the OpenFoam has the remeshing capability?
Old   October 16, 2012, 06:35
Ivanet is on a distinguished road
Hi Mostafa,
I am not sure if I understand properly what you are trying to do. Could you send some sketch?
I would also suggest to check the general grid interface (GGI), which should allow you to rotate the square.
Greetings
Iván
Ivanet is offline   Reply With Quote
Old   October 16, 2012, 10:24
adambarfi's Avatar
Mostafa Mahmoudi
Originally Posted by Ivanet View Post
Hi Mostafa,
Greetings
Iván
Hi Ivan,
Thank you for your reply. I attach you a mesh that I have solved it in FLUENT.
I tried ggi before, but I couldn't find it in src or internet. I'm using OF-2.1.0.
Old   October 16, 2012, 10:46
If you are using OF210 you should have a look at AMI, which is very similar to GGI.
GGI is only available in OF1.6-ext (maybe also in OF1.5-dev, I am not sure).
Greetings
Ivan
Old   May 15, 2013, 01:45
Nima Samkhaniani
nimasam is on a distinguished road
dear mostafa, did you find why this error happens?
Telegram channel (https://telegram.me/openfoam4Iranian)
My Weblog (http://openfoam.blogfa.com/)
Training Course on OpenFOAM at (http://www.isme.ir/)
nimasam is offline   Reply With Quote
Old   May 15, 2013, 03:30
adambarfi's Avatar
Mostafa Mahmoudi
Dear Nima,
Which error? the GGI is only available in OF1.6-ext and I decided to simulate it with Fluent and I did it, but I'm waiting for summer vacation to test it with openFOAM.
best,
Mostafa
Thread Tools
Trackbacks are On
mass flow in is not equal to mass flow out saii CFX 2 September 18, 2009 08:07
Boiling of water with hot air Dr. Flow Squad CFX 2 July 27, 2009 07:37
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
Separation phenomenon of water, droplet and air Raymond CFX 0 July 9, 2004 22:59
Help!!!problems in air jet into water bath kim FLUENT 4 June 9, 2003 07:04
