Modification in Deardorff SGS
Like Tree2Likes
  • 1 Post By ehsan
  • 1 Post By Tobi
Old   August 18, 2016, 05:57
Default Modification in Deardorff SGS
Ehsan
ehsan is on a distinguished road
We try to add a formula based on the gradient of velocity in the Deardorff stress model and develop a model (Modulated Gradient model). However, we encounter the errors that is attached. I would be regretful if someone could advice us in this issue, because as soon as we add a few lines of:
const volSymmTensorField Gij_
Gij_.component(symmTensor::XX) = ((sqr(delta())/12.0)*(fvc::grad(U).component(tensor::XX)*fvc::gra d(U).component(tensor::XX)))+((sqr(delta())/12.0)*(fvc::grad(U).component(tensor::XY)*fvc::gra d(U).component(tensor::XY)))+((sqr(delta())/12.0)*(fvc::grad(U).component(tensor::XZ)*fvc::gra d(U).component(tensor::XZ)));
in the void MyDeardorffDiffStress::correct(const tmp<volTensorField>& gradU)
the attached error appears.
Regards
File Type: jpg Screenshot from 2016-08-18 11-04-0511.jpg (189.2 KB, 16 views)
Elyas_Mosibat likes this.
ehsan is offline   Reply With Quote
Old   August 18, 2016, 07:03
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
the first problem is that the field U is not available in your function. So you can not call fvc::grad(U). What you can do is replacing fvc::grad(U) by gradU. Another way is to get access to the U field by taking it from the registry database from OpenFOAM and build the gradU field again (but in my opinion this would be senseless if you already have gradU available).
There are other mistakes you made but just one hint.
Think about your code: calling
fvc::grad(U) six times is just waste of computational resources. Call it once, save that field and use that field or just use the gradU that is already available.
PS: Use Code-tags.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   August 19, 2016, 07:40
Ehsan
Thank you. We move in this direction but now the code do not understand component command for gradU, as the attached file depicts.
Old   August 19, 2016, 14:25
Tobi's Avatar
Tobias Holzmann
Okay,
you are using this field:
So gradU is a volTensorField. To know which functions you can use, you use Doxygen... http://cpp.openfoam.org/v4/
Then you can search for volTensorField. Here you will realize that this is derived from a GeometricField. So you check the GeometricField class. Here you will find a lot of functions. The function you can call is component. So you can do something like that:
tmp< GeometricField< cmptType, PatchField, GeoMesh > > theComponents = gradU.component();
Then you can go further. Maybe it is also possible to get the components directly like:
scalar oneComponent = gradU[0].component().xx();
or
scalar oneComponent = gradU[0].component()[0]
I have no enviroment at the moment, so no chance to check it
Hope you get some further steps.
Another way is to search the source code for the volTensorFields and hope that you get to a part where you find what you need
Have a nice weekend.
Keep foaming,
Tobias Holzmann
Old   August 20, 2016, 12:34
Ehsan
Thank you!
We tried lot of combinations, all our trials and their errors are put in a doc file here:
https://fumdrive.um.ac.ir/index.php/s/VqX1vK0FbbkFST3
1- Here, I attached the error of applying the lines attached in "Lines" image below as file "Error"
2- Once we tried the other command you suggested:
the "error2" appears. I'd be more than happy if you help us in this regards.
Ehsan
Compressible vs incompressible SGS model! zhangyan Main CFD Forum 10 June 4, 2016 04:39
Issues on modelling of isotropic part of Reynolds (SGS) stresses Likun OpenFOAM Programming & Development 2 January 25, 2016 02:51
Smagorinsky Sub-Grid Turbulence Model vs. Deardorff oksero Main CFD Forum 4 July 29, 2015 10:43
How to exploit SGS kinetic energy with Smagorinsky model in LES babakflame OpenFOAM Programming & Development 3 December 14, 2014 06:58
What is really SGS dissipation term in LES? mrf6166 Main CFD Forum 0 January 5, 2014 06:57
