October 10, 2012, 18:03 |
dynOneEqEddy and homogeneousDynOneEqEddy
I have OF 2.1.1 installed on my machine today I was trying to use dynOneEqEddy model and was NOT able to find it. The name is still there included for compressible LESModels in openfoam, but its no more available in 2.1.1. Instead you can find homogeneousDynOneEqEddy Model, I would like to ask if there are any differences between these two? It would be of great help if someone could point that out. Regards, Awais |
October 12, 2012, 03:30 |
Dejan Morar
Rep Power: 16 |
Hi Awais,
homogeneousDynOneEqEddy is similar to the dynOneEqEddy. In the .C files you can see that constant ck is defined as dimensionedScalar, and in the both models is calculated on the same way. There is just small difference in coding.. I'm using OF 2.1.x and now I see that dynOneEqEddy in 2.1.x is actually the locDynOneEqEddy in 1.7.1 (and probably also in 2.something)... I've checked it briefly, not 100 % sure.. Regards, Dejan |
October 12, 2012, 10:29 |
Hi Dejan,
Thanks for your reply. I will also try to look into detail. But could you please show me some example LESProperties and fvSchemes and fvSolution file that you used with dynOneEqEddy model. Regards, Awais |
October 12, 2012, 10:45 |
In fact you are right they are perfectly the same.
Regards, Awais |
October 12, 2012, 10:49 |
Dejan Morar
Rep Power: 16 |
Hi once again.
Just check the channelFoam tutorial >> channel395 case. I use the same LESProperties, fvSchemes and fvSolution. The only difference is that instead of oneEqEddy I usually use dynOneEqEddy. I tried to make some small changes but didn't see any big influence on the results. Dejan |
Reference to oneEqEddy and dynOneEqEddy | Cotten | OpenFOAM Programming & Development | 6 | September 30, 2018 12:06 |
LES Dynamic models details | lakeat | OpenFOAM Programming & Development | 10 | May 19, 2011 07:46 |
dynOneEqEddy for Compressible Flow | deji | OpenFOAM | 2 | November 17, 2010 05:57 |
Bug in Dynamic 1Eq Eddy Viscosity LES Model Incompressible flow | harishg | OpenFOAM Bugs | 5 | December 2, 2008 18:18 |
