-   -   fvm::div(phi, Ug)...how to insert properly? (http://www.cfd-online.com/Forums/openfoam-solving/108207-fvm-div-phi-ug-how-insert-properly.html)
sawyer86 October 17, 2012 05:11
(U_j+Ug_j)*d(U_i+Ug_i)/dx_j...how to insert properly?
Hi there,
My question can be seen even from this prospective. I have to insert in the equation this term:
where Ug_i are the components of a given velocity field and U is the velocity I want to solve. This above is the convective term in the expression "u*grad(u)"-like
how can I do? Is it possible?
Thank you in advance!
treima October 17, 2012 05:23
how did you initialise Ug, is it equal to the initialisation of U? Or perhaps there are some problems with the implicit and explicit treatment. You can have a look at this thread: http://www.cfd-online.com/Forums/ope...operation.html. There is a description of the same problem.
regards
treima
akidess October 17, 2012 05:24
You do not solve for Ug, hence that term is explicit. phi is not the variable you solve for, it's the data from the previous iteration.
sawyer86 October 17, 2012 05:32
one question. Do you say that the volume velocity flux is given from the previous iteration...that's so the way how icoFoam treats the non linear-convective term in the way to linearize it, am I right?
This linearization influence the calculation of UEqn.H()...but if I do insert that term explict how does UEqn.H() must change?
Thank you very much
sawyer86 October 17, 2012 05:36
Sorry I did not explain this term. It is essentially the convective term when you do a kind of linearization starting from a base flow...like in the RANS, but different...
Then the term i exactly want to add is the part of the above expression:
U_j*dUg_i/dx_j
sawyer86 October 17, 2012 05:45
Originally Posted by treima (Post 387042)
regards
treima
Thank you for the answer but i had a look of that thread and this is not just what I am looking for. By the way thank you again!
Regards
