Home > Forums > OpenFOAM Running, Solving & CFD
Time step independence?
Old   October 19, 2012, 09:35
Default Time step independence?
David Gaden
marupio is on a distinguished road
Basic stuff here.
I cannot get consistent results from pisoFoam. I have a simple cavity with a cross flow inlet / outlet. I vary the time step from 0.001 to 0.0000001 s and the resulting pressure fields vary by 20-60%.
Does anyone have any ideas?
So far I've observed:
  • Changing the cavity size has no effect (between 0.1m and 10m)
  • Changing the mesh density has no effect (10x10 vs 100x100)
  • Turbulence model has no effect (kEplison vs disabled)
Yeah, I'm an OpenFOAM developer... not a user.
-Dave
Follow me on twitter @DavidGaden
marupio is offline   Reply With Quote
Old   October 20, 2012, 21:54
Awais Ali
owayz is on a distinguished road
Send a message via MSN to owayz
Hi David,
are you comparing averaged pressure or just pressure at some time ?
Regards,
Awais
owayz is offline   Reply With Quote
Old   October 22, 2012, 06:49
chegdan's Avatar
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
Dave,
Are you sure that there is convergence between all of your fields at each timestep? If not, then this will have a big affect on your pressure field. Adding outer-correction will ensure convergence at each timestep. Have you looked at using pimpleFoam instead of pisoFoam? This is suggested on interFoam: timestep / mesh / PISO nCorrector dependency
Dan
Find me on twitter @dancombest and LinkedIn
chegdan is offline   Reply With Quote
Old   November 5, 2012, 23:50
David Gaden
@Awais
I am calculating an RMS error across the entire pressure field. Average pressure doesn't vary nearly as much.
@Dan
Thanks for the suggestions, I will try implementing pimpleFoam into the solver.
I've attached some pictures of the pressure and flow field. I'm getting a pressure fluctuation at the inlet, and discontinuities at the corners. I'm sure this is a rookie problem, but it mystifies me. These images are for velocity driven flow. When I do pressure driven flow, though, it smooths out, but I still can't get timestep independence.
Thank you all for your suggestions. I will continue troubleshooting this between my full-time job and parenthood!
-Dave
Thread Tools
Trackbacks are On
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Hydrostatic Pressure and Gravity miliante OpenFOAM Running, Solving & CFD 132 October 7, 2012 22:50
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 9 January 3, 2012 09:06
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 10:20
