Same SimpleFOAM Case converges with openFOAM 2.1 but diverges with openFOAM 2.0.1 |
October 21, 2012, 23:07 |
edy
I have two machines
1) OpenSUSE 12.1 with OpenFOAM 2.1.x [http://susestudio.com/a/2qtLK2/geekocfd?version=3.1.0] 2) CAELINUX2011 launched inside VirtualBOX on a XP 64 machine with openFOAM v2.0.1 http://www.caelinux.com/CMS/index.ph...d=69&Itemid=58 I launch the following case of a sphere invested by a flow of air t 14.6 m/s https://www.dropbox.com/sh/gg1ypj0c1...here.case.test 1) in OpenSUSE with with OpenFOAM 2.1.x, I get convergence and no error Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.x-63f6b7e20176 Exec : simpleFoam Date : Oct 22 2012 Time : 03:00:21 Host : "linux-baef" PID : 18519 Case : /home/serena/sphere.medium.40000vertex.withCoeffs.USB.test nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting RAS turbulence model kOmegaSST kOmegaSSTCoeffs { alphaK1 0.85034; alphaK2 1; alphaOmega1 0.5; alphaOmega2 0.85616; gamma1 0.5532; gamma2 0.4403; beta1 0.075; beta2 0.0828; betaStar 0.09; a1 0.31; c1 10; } No field sources present SIMPLE: no convergence criteria found. Calculations will run for 105 steps. Starting time loop Reading surface description: yNormal Time = 1 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.0576103, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.051907, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 0.0754043, No Iterations 3 GAMG: Solving for p, Initial residual = 1, Final residual = 0.0981085, No Iterations 5 time step continuity errors : sum local = 0.100654, global = -0.00926128, cumulative = -0.00926128 smoothSolver: Solving for omega, Initial residual = 0.0394307, Final residual = 0.00164586, No Iterations 3 smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.0804227, No Iterations 3 ExecutionTime = 1 s ClockTime = 1 s forceCoeffs output: Cd = 0.945971 Cl = 0.00211079 Cm = -0.426151 Cl(f) = 0.427207 Cl(r) = -0.425096 .... Time = 104 smoothSolver: Solving for Ux, Initial residual = 0.00150213, Final residual = 7.9976e-05, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 0.00335438, Final residual = 0.000166074, No Iterations 3 smoothSolver: Solving for Uz, Initial residual = 0.00404789, Final residual = 0.000185933, No Iterations 3 GAMG: Solving for p, Initial residual = 0.0189557, Final residual = 0.00182748, No Iterations 1 time step continuity errors : sum local = 0.00550264, global = -3.908e-05, cumulative = -0.0017971 smoothSolver: Solving for omega, Initial residual = 0.000176399, Final residual = 1.75706e-05, No Iterations 2 smoothSolver: Solving for k, Initial residual = 0.00183807, Final residual = 6.93889e-05, No Iterations 3 ExecutionTime = 35.54 s ClockTime = 36 s forceCoeffs output: Cd = 0.00226424 Cl = -0.00123669 Cm = -0.000745832 Cl(f) = 0.000127488 Cl(r) = -0.00136418 Time = 105 smoothSolver: Solving for Ux, Initial residual = 0.00146514, Final residual = 7.74717e-05, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 0.00327494, Final residual = 0.000160581, No Iterations 3 smoothSolver: Solving for Uz, Initial residual = 0.00394729, Final residual = 0.000181077, No Iterations 3 GAMG: Solving for p, Initial residual = 0.0187608, Final residual = 0.00179919, No Iterations 1 time step continuity errors : sum local = 0.00541478, global = -0.000123, cumulative = -0.0019201 smoothSolver: Solving for omega, Initial residual = 0.000174777, Final residual = 1.71551e-05, No Iterations 2 smoothSolver: Solving for k, Initial residual = 0.0018046, Final residual = 6.76978e-05, No Iterations 3 ExecutionTime = 35.83 s ClockTime = 36 s forceCoeffs output: Cd = 0.00225507 Cl = -0.00125446 Cm = -0.000737782 Cl(f) = 0.000110551 Cl(r) = -0.00136501 End Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.0.1-51f1de99a4bc Exec : simpleFoam Date : Oct 22 2012 Time : 09:43:12 Host : orion PID : 2050 Case : /media/sf_My_Documents/linux.Ferries.Carrier/sphere.medium.40000vertex.withCoeffs.USB.test nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting RAS turbulence model kOmegaSST kOmegaSSTCoeffs { alphaK1 0.85034; alphaK2 1; alphaOmega1 0.5; alphaOmega2 0.85616; gamma1 0.5532; gamma2 0.4403; beta1 0.075; beta2 0.0828; betaStar 0.09; a1 0.31; c1 10; } SIMPLE: no convergence criteria found. Calculations will run for 105 steps. Starting time loop Reading surface description: yNormal Time = 1 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.0997099, No Iterations 223 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.0996995, No Iterations 23 smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 0.09999, No Iterations 336 GAMG: Solving for p, Initial residual = 1, Final residual = 0.0867693, No Iterations 4 time step continuity errors : sum local = 0.37954, global = -0.0213585, cumulative = -0.0213585 smoothSolver: Solving for omega, Initial residual = 0.370863, Final residual = 0.0369602, No Iterations 151 smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.0978377, No Iterations 63 ExecutionTime = 10.48 s ClockTime = 14 s forceCoeffs output: Cd = 1.60633 Cl = 0.00632664 Cm = -0.724241 ....since the beginning the Cd is different Time = 8 smoothSolver: Solving for Ux, Initial residual = 0.999943, Final residual = 0.0719959, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 0.999943, Final residual = 0.0524752, No Iterations 3 smoothSolver: Solving for Uz, Initial residual = 0.999946, Final residual = 0.0524753, No Iterations 3 #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/libc.so.6" #3 Foam::GAMGSolver::scalingFactor(Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double> const&, Foam::Field<double> const&) const in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #4 Foam::GAMGSolver::scalingFactor(Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double>&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #5 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #6 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #8 Foam::fvMatrix<double>::solve() in "/opt/openfoam201/platforms/linux64GccDPOpt/bin/simpleFoam" #9 in "/opt/openfoam201/platforms/linux64GccDPOpt/bin/simpleFoam" #10 __libc_start_main in "/lib/libc.so.6" #11 in "/opt/openfoam201/platforms/linux64GccDPOpt/bin/simpleFoam" Floating point exception Why? is it because in Opensuse I have Build : 2.1.x-63f6b7e20176 and in CAELINUX Build : 2.0.1-51f1de99a4bc? Or is something else? |
October 22, 2012, 02:24 |
Alberto Passalacqua
Rep Power: 36 |
Hi Serena,
first of all, thank you for using GeekoCFD. Does it work well for your needs? I am not sure why you do not obtain a converged solution with openfoam 2.0.1, but it is possible that some bug was fixed in 2.1, which might explan the difference you notice. That's why it is often convenient to use the latest version of OF, or the git version. Best,
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
October 22, 2012, 02:58 |
edy
Alberto
thank you for your quick reply. Yes your GeekoCFD works beautifully, it is a very convenient tool and I love also the choice of OpenSuse instead of Ubuntu, more sharp and well focused environment. By the way, I would like to ask you, when you submit a new Geeko release: could you include in the scientific software also : 1) SALOME (a nice alternative to gmsh) http://www.salome-platform.org/ 2) SCILAB (a nice alternative to R) http://www.scilab.org/ Bye Serena |
October 22, 2012, 11:25 |
#4 | ||
Alberto Passalacqua
Rep Power: 36 |
Hi Serena,
thank you for your feedback. Quote:
Thank you for your suggestions
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
SimpleFoam case with SpalartAllmaras turbulence model implemented | nedved | OpenFOAM Running, Solving & CFD | 2 | November 30, 2014 22:43 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
