[swak4Foam] assign non uniform velocity inflow boundary condition preferably by points?
Old   October 30, 2012, 02:36
Default assign non uniform velocity inflow boundary condition preferably by points?
pepe.aero is on a distinguished road
I'm looking for a way to assign non uniform velocity inflow boundary condition preferably by points rather than using algebraic expression.
Can anyone tell me if swak4foam is able to do it?
Thanks all for your support.
Regards,
Andrea
pepe.aero is offline   Reply With Quote
Old   November 5, 2012, 12:44
waiting for some replies, in the meantime I've taken a quite deep look to swak4foam. It's clear that it could be used to assign velocity profile manipulating scalar expressions.
But it's still not completely clear to me how to solve my problem...I try to explain better the issue:
I need to assign non uniform velocity inlet, with (Ux, Uy, Uz) varying along vertical axis in agreement with a law defined by pow, sin, cos, sqrt. Since the velocity profile is varying along vertical axis some operators (pow, sqrt) should work for vector.
As example, part of the formula is:
A = 20 * ( z/40 )^0.2
where z is a vector of coordinates in vertical direction. So in my mind the problem is the pow() operators, that should work for the vector z.
Any suggests to implement such a condition are welcome.
Thanks in advance.
Best regards,
Andrea
Old   November 6, 2012, 03:09
Michiel
michielm is on a distinguished road
Hi pepe,
If you take a look here: http://openfoamwiki.net/index.php/Co...ression_syntax
You can see that the power is only defined for scalars.
However, if I'm not mistaken (someone please correct me if I am wrong), pos().z etc are not vectors but rather lists of scalars. This explains why this example on the same site is apparently supposed to work:
funkySetFields -field gamma -expression 0 -time 0 -keepPatches -condition "pow(pos().x-1.5,2) + pow(pos().y-1.5,2) < pow(3,2)"
So for your example I would think something like this could work:
20*pow(pos().z/40,0.2)
Cheers,
Michiel
michielm is offline   Reply With Quote
Old   November 6, 2012, 04:39
Originally Posted by michielm View Post
Hi pepe,
Cheers,
Michiel
Hi Michielm,
thank you very much for your reply.
Maybe you have focused the issue. I need to assign boundary condition, so I think I should use funkySetBoundaryFields instead of funkySetFields.
It's not completely clear to me the usage of funkySetBoundaryFields, also looking on the example swak4Foam/Examples/FunkySetBoundaryFields/funkySetBoundaryDict.dambreak .
Here is the content of the example:
velocities {
field U;
expressions
target value;
patchName leftWall;
variables "maxY=max(pts().y);thres=0.25*maxY;";
expression "(pos().y<thres) ? vector(1,0,0)*(maxY-pos().y) : vector(0,0,0)";
target value;
patchName rightWall;
variables "maxY=max(pts().y);";
expression "vector(0,1,0)*(maxY-pos().y+p_rgh)";
dropIn {
field alpha1;
expressions
target inletValue;
patchName atmosphere;
variables "maxX=max(pts().x);thres1=0.4*maxX;thres2=0.6*maxX ;";
expression "(pos().x>thres1 && pos().x<thres2) ? 1 : 0";
Do I have to add these lines at the end of my controlDict??
How do I have to modifiy also the 0/U file?
In general I have no idea about how to use funkySetBoundaryFields. If you have any experience about its usage it could be great if you'll post a simple but complete working example!
Thanks in advance!
Yours sincerely,
Andrea
Old   November 6, 2012, 09:10
I keep working on non uniform condition with swak4Foam and I'm quite close to solution.
I am now using funkySetFields to initialize boundaries and internal field to a desired velocity profile.
This is my funkySetFieldsDict:
FoamFile
version 2.0;
format ascii;
class dictionary;
object controlDict;
expressions
velocities
field U;
// this with pos() is working:
// expression "pos().z<75.0 && pos().z>=0.0 ? vector(1.0,0.0,0.0)*(10.288*pow(pos().z/40.0,0.1)) : vector(10.955472,0.0,0.0)";
// this with pst() in not working
expression "pts().z<75.0 && pts().z>=0.0 ? vector(1.0,0.0,0.0)*(10.288*pow(pts().z/40.0,0.1)) : vector(10.955472,0.0,0.0)";
keepPatches 0;
The following error is reported:
Create time
Create mesh for time = 0
Time = 0
Using funkySetFieldsDict
Part: velocities
Modifying field U of type volVectorField
Putting "pts().z<75.0 && pts().z>=0.0 ? vector(1.0,0.0,0.0)*(10.288*pow(pts().z/40.0,0.1)) : vector(10.955472,0.0,0.0)" into field U at t = "0" if condition "true" is true
--> FOAM FATAL ERROR:
Parser Error for driver FieldValueExpressionDriver at "1.9-12" :"syntax error, unexpected number"
Context of the error:
- Driver constructed from scratch
Evaluating expression "pts().z<75.0 && pts().z>=0.0 ? vector(1.0,0.0,0.0)*(10.288*pow(pts().z/40.0,0.1)) : vector(10.955472,0.0,0.0)"
From function parsingValue
in file lnInclude/CommonValueExpressionDriverI.H at line 876.
FOAM exiting
The issue is that I need to use vertices ( pts().z ) at z=0 instead of the cell centres ( defined by pos().z ) which have not zero as vertical coordinate (first cell centre is at z=2.5 in my system).
The final aim is having value expression zero at coordinate z=0, and so the desired velocity profile.
Hope the brief explanation could be clear and someone can help me to close the issue.
Thanks again,
Andrea
Old   November 14, 2012, 17:22
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
Originally Posted by pepe.aero View Post
FoamFile
version 2.0;
format ascii;
class dictionary;
object controlDict;
expressions
velocities
field U;
keepPatches 0;
Create time
Time = 0
Part: velocities
FOAM exiting
Thanks again,
Andrea
Catching up on the MessageBoard-stuff. Not quite sure: you need a boundary condition right? Then for a first try groovyBC would be the easiest.
Anyway: problem here is that 75 evaluates to a volumeField (or a patchValue if you're doing a boundary condition) and you're comparing it to a pointField. To make 75 a pointField use "interpolateToPoint(75)" ("toPoint(75)" in groovyBC and funkySetBoundaryFields). To get point values back to the cells use interpolateToCell (toFace if you're working on the patch)
Some examples use toPoint/toFace so check there: rule of thumb is swak does not automatically transform your data between cells/points/faces it wants you to say so
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
gschaider is offline   Reply With Quote
Old   March 27, 2015, 11:03
Minisasi is on a distinguished road
Hi Michielm,
velocities {
field U;
expressions
target value;
patchName leftWall;
target value;
dropIn {
field alpha1;
expressions
target inletValue;
Thanks in advance!
Yours sincerely,
Andrea
Did you get how to solve this problem? I am facing the same.
Could you help me? sorry for the silly question.
I have just started to use these utilities and from their descriptions they look so powerful... I'd like to use them.
Thanx for your time
Minisasi is offline   Reply With Quote
Old   March 27, 2015, 19:21
Default groovybc
Hashme is on a distinguished road
Hi guys,,
I am trying to change inlet velocity based on certain properties calculation (like temperature at certain location ) using groovybc but it is not working fine can somebody help me with this please
inlet
type groovyBC;
valueExpression "(Tave<299)? vector(0,0,0):vector(0,0,0.3)";
variables "Tave@location=average(T);";
value uniform(0 0 0.3);
and I got this error field Tave not existing or of wrong type
Best,,
Hashme is offline   Reply With Quote
Old   March 29, 2015, 12:18
Sorry for bothering.
I solved my problem. (Didn't install correctly my swak4Foam, and didn't have the right expression.)
Forget my posts (I didn't know how to delete them.)
Thanks
|  \\    /   O peration     | Version:  2.3.0                                 |
Build  : 2.3.0-f5222ca19ce6
Exec   : funkySetBoundaryField -time 0
Date   : Mar 29 2015
Time   : 12:13:28
Host   : "giuli_work"
PID    : 4575
Case   : /home/giuli/OpenFOAM/giuli-2.3.0/run/a008_pisoEC/case_SBF
nProcs : 1
swakVersion: 0.3.1 (Release date: 2014-07-11)
Create time
--> FOAM Warning :
    From function dlOpen(const fileName&, const bool)
    in file POSIX.C at line 1179
    dlopen error : libswak4FoamParsers: cannot open shared object file: No such file or directory
--> FOAM Warning :
    From function dlLibraryTable::open(const fileName&, const bool)
    in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99
    could not load "libswak4FoamParsers"
--> FOAM FATAL IO ERROR:
"ill defined primitiveEntry starting at keyword 'expressions' on line 21 and ending at line 82"
file: /home/giuli/OpenFOAM/giuli-2.3.0/run/a008_pisoEC/case_SBF/system/funkySetBoundaryDict at line 82.
    From function primitiveEntry::readEntry(const dictionary&, Istream&)
    in file lnInclude/IOerror.C at line 132.
FOAM exiting
giuli@giuli_work:~/.../a008_pisoEC/case_SBF$
And this is my dictionary file
//*--------------------------------*- C++ -*----------------------------------*\
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      funkySetBoundaryDict;
velocities
    field U;
    expressions
            target value;
            patchName inlet;
            variables(
    "Umax=0.001;"
    "yCoord=pos().y;"
    "yCoordMax=max(yCoord);"
    expression "yCoord/yCoordMax * Umax* vector(1,0,0)";
Hello, I am new to these utilities (as you can see), and I need some help.
I created my funkySetBoundaryDict where I a imposing a velocity profile at the inlet. The one above is the error I get. Any ideas about what I've done wrongly?
Sorry for taking your time...
Thx for your helps!
Cheers
Old   November 18, 2016, 12:08
Default Hi Minisasi, I am currently facing the identical problem as you did
Linyan X
linyanx is on a distinguished road
Thanks
Date   : Mar 29 2015
Time   : 12:13:28
Host   : "giuli_work"
PID    : 4575
nProcs : 1
Create time
--> FOAM Warning :
--> FOAM Warning :
FOAM exiting
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
velocities
    field U;
    expressions
            target value;
            patchName inlet;
            variables(
    "Umax=0.001;"
    "yCoord=pos().y;"
Thx for your helps!
Cheers
Hi Minisasi,
I wonder if you have already figured out the way to solve this error? I've just seen your post which is the same as I did. If you have any futher update, please let me know.
Looking forward to communicate with you!
Best,
Antelope
linyanx is offline   Reply With Quote
Old   November 18, 2016, 13:04
As I mentioned above, my problem was related to the installation of swak4foam. So check it out.
this ( https://openfoamwiki.net/index.php/Installation/swak4Foam/Downloading ) is the link from which I download, and this ( https://openfoamwiki.net/index.php/Installation/swak4Foam ) the one from which I check my installation.
Try to have a look at that. When you are done check also the way you are writing your equation in the funkySetBoundaryDict. Some times it is just a matter of very silly mistakes you cannot even think about!
Good luck
boundary condition, inlet, non uniform, swak4foam
dsmcFoam setup hherbol OpenFOAM Pre-Processing 1 November 19, 2021 01:52
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 09:42
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 17:38
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 08:44
