October 31, 2012, 12:52 |
Parallel transient file input/output
Anonymous
Rep Power: 14 |
Hi Foamers,
I am running an LES simulation on a large scale research cluster with around 100 cores. I plan on writing out time-step result files at a fairly high frequency. The issue I am having is that the rules surrounding the use of the cluster discourage a lot of I/O with MANY SMALL FILES, so when openfoam is parallelized, having 100 files/timestep backed up will become a major issue. I was wondering if anyone knows whether or not it's possible to perform a sort of 'reconstructPar' command during output so that I only end up with 1 time directory per backup, instead of 100's. Cheers |
Display Modes | |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' | mfiandor | OpenFOAM Installation | 2 | January 25, 2010 10:50 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 05:26 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
PHI file structure | Eugene | Phoenics | 9 | November 2, 2001 23:00 |
