Home > Forums > OpenFOAM Running, Solving & CFD
How to couple regions
Old   November 5, 2012, 06:45
Default How to couple regions
Koga is on a distinguished road
I defined two regions, a tiny and a big one. Both meshed with tetrahedrons.
We assume that one region is hot and one region is cold. I want to simulate the heat transfer between these regions. For that I use the chtMultiRegionSimpleFoam solver.
Now I am trying to couple the two patches, which are on the same plane.
I did it the same way like they did it in the 'heatTransfer/chtMultiRegionSimpleFoam/multiRegionHeater' tutorial.
I changed the boundary type of the two connected patches from patch to mappedWall (and added sampleMode, offset and all other necessary settings) in 'constant/{regionname}/boundary'. Furthermore I changed the initial condition type from 'zeroGradient' to 'compressible::turbulentTemperatureCoupledBaffleMi xed' and all necessary settings.
If I try to simulate this case, I will get this error message:
'Did not find sample (29.90284 38.34374 49) on any processor of region Solid2'
Solid2 is the tiny region. It might be a problem with the defined offset, but I can't imagine why. The offset is always set to (0 0 0), because both connected patches are on the same plane. Am I wrong? Or is there another reason for this error?
Koga is offline   Reply With Quote
Old   November 7, 2012, 05:11
I found a solution. The problem was that both connected patches must have the same size. So I created another patch on top of the big box that fits to the bottom patch of the tiny box. I used the following createPatchDict:
pointSync false;
patches
        name test_patch;
        patchInfo
            type patch;
        set test_set;
The faceSet 'test_set' is defined in my TopoSetDict:
actions
        name    test;
        type    faceSet;
        action  new;
        source  boxToFace;
        sourceInfo
            box (45 45 49.99) (55 55 50.01);
The definition of the faceSet is my next problem. For this simple geometry everything is fine. But I am working with a more complex geometry and the box-command doesn't fit for patches that have many curves.
Just imagine there is a very complex domain (but still tiny) instead of the tiny box. How can I get all the faces, that are connected with the bottom patch of the complex domain, from the top patch of the big box in this case?
Thread Tools
Trackbacks are On
Splitting regions king_steve STAR-CCM+ 1 September 27, 2010 12:48
Couple error Yehia CD-adapco 3 January 25, 2007 04:58
Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 2 July 15, 2005 04:15
couple and spin index novice CD-adapco 6 July 8, 2004 03:31
couple problems leo CD-adapco 3 January 28, 2003 04:09
